95 eg hatch B series intercooler piping.
I need input on the best setup of intercooler piping. DIY kits vs. a performance shop custom making you a setup.
Thanks
Thanks
Re: 95 eg hatch B series intercooler piping.
shop kits will be more money but likely better made.
diy kits could fit better but will take more time and might not look as good.
personally i always make my own piping. order up some bends, cut, fit, tack and then take them off to put on the bench and weld.
so this isnt much but its pretty much all of the pipes you can see. fitment is pretty much spot on, i even made some mounting tabs to bolt the pipes down
build your own .. go to CXRACING order up a 8 or 9pc bend kit, cut and piece them together with tape and take the piping to your local welder and have them welded. that is if you dont have your own welder. you can have quality piping made to your spec without the chance of bad fittment.
buda18
08-18-2006 12:06 PM
