81.5mm stock sleeve ls/vtec turbo recommendations
Looking for some help picking a turbo for my new project.
I'm building a stock sleeve 81.5mm ls vtec motor for my integra sedan, 9:1 compression, eagle rods, gsr transmission, itr intake manifold, ferrea dual valve springs and retainers, with undecided cams (pro 1's or itr...) ,water/meth injected and tuned on pump gas (93). The car will have working a/c and either a ram horn, inline pro or spa top mount manifold with three inch exhaust and down pipe.The a/c compatable part with limit my turbo selection and size but its a must for this car!
I will use the NLR AMS-500 boost controller with boost by gear. I mainly get to do 1st-3rd gear runs with 3rd gear being full boost. My last setup was a stock block b16a turbo with a t3/t4 57 trim .63 a/r turbo that produced 375 whp and I loved feeling the boost early and would like that in the new setup but produce more power! Im looking to be in the mid to upper 400's in power with 300+ ft/lbs of tq.
any thoughts on t3/t4 60-1, gt35r, sc61, 6262? twin scroll is out of budget so dont even mention them!
Re: 81.5mm stock sleeve ls/vtec turbo recommendations
Cool I'm doing tha same build but with weicopistons and
supertech vale train victorx intake manifold with a Afi turbo manifold
idk wat turbo to do with yet but my set up is going in a db2
lookin for 450-500 up stock sleeves tun on hondata s300 on ether
e85 or 93 pump gas..
turbosol_16
01-03-2007 09:38 PM
