70mm Edelbrock throtle bodie
I recently got my car tuned but iam using a stock throtle body, i have a 70mm edelbrock throtle bodie but it dosent have the water lines for the iac will this cause the idle to go up and down thats why i didnt use it can any one help, thanks
Re: (rudebwoy)
The VictorX 70mm and 75mm throttle bodies are completely different fron the 65mm PerformerX throttle body. They are basically Mustang throttle bodies with throttle cable connections and adapter plates for putting them on a Honda/Acura. They have no IACV air passage, and you have to do something different -w- the IACV if you want your idle to be controlled by your ECU.
I drilled a port on my IACV and put a breather filter on it, and filled my IACV passage in on my manifold before I had it port matched to the TB.
Re: (jaydim)
i have the victor x intake with the 70mm throttle body and it idles perfect! put a thin sheet metal block off between the iacv and blocked and ran water lines where needed to be. no probs any where or any cel's using power fc to tune
Re: 70mm Edelbrock throtle bodie (jaydim)
I've got a 99 D16Y8, installed a 71mm TB with my own block off plate. Just connected the two hoses together. Idle was not effected at all....
hkrichard
04-27-2008 06:03 PM
