700whp+ LS/V e85 turbo build!!! Specs and tech needed!!!!
I'll try and keep this short and to the point, need all info possible on lsv turbo builds , possibly full SETUPS so I can try and do the combo I want (E85) (precision turbo) , All info is greatly appreciated , please be very specific and possible sources would also be greatly appreciated, I'm looking fore all info on how to make a 1999 LS into a 700hp fire breather and put it in a 1991 Ef si hatch, I DO need tech advise on what I need to do to the car to make it safe and legal for track , I'm ok with pushing the limit on street ability, all info from fuel to suspension is needed. I so know some info about my build but don't kind being reassured about what I do know so feel free to comment bellow and thank in advance for your help in making my dream come true
Re: 700whp+ LS/V e85 turbo build!!! Specs and tech needed!!!!
Ill tell you how
Go autoworks kit
Turbo from the shodan
Ignitor bypass
Tune from t1
Cams from ddtech
Full blown fuel system
nos bottle from hairys you're gonna need 2
Go autoworks kit
Ignitor bypass
Tune from t1
Cams from ddtech
I never narc'd on nobody!
the big ones. And tell Harry...you'll need them by tomorrow.
OP, theres an FAQ's sticky that will quite literally answer every question you have right now, more questions you'll have tomorrow, and then some questions you never realized even existed. Read it. Go to sleep, then read it again tomorrow. Read it a third time during your lunch break. Keep reading it.
Thank you I'll look, the one I have found is from 2011 and I'm just thinking that newer combos are out there
Who is Mr Robot?
If you have to ask how to make 700hp it will never happen... plus no one here will spoon feed you answers. every reply in this thread has been sarcastic and you haven't even caught on yet...
do your own research, read the FAQs at the top of this forum... repeatedly. because no one will tell you what needs to be done.
do you even need 700hp? what's the purpose of this car? N ef is already so light that traction is an issue with 300hp... the suspension work and kind of rubber needed to even begin to transfer that kind of power to the ground takes this out of the realm of a street car. add in the car needs a steady diet of very expensive race gas (15 dollars a gallon at the cheapest) because it will never survive on pump gas.
me thinks this is a waste of time pipe dream... the money investment is well north of 20,000 dollars for a reliable high power setup, you can't cheap out and cut corners on a build with 5 times the power of the stock motor.
Time for a reality check.
/thread.
Who is Mr Robot?
Pretty much. not to **** on your rainbow but this is one of those if you have to ask you'll never understand the answer anyways kind of deals
I'm a 29 year old man not a child hopefully this will make you take me seriously , I know I'm using a turbo from precision (6262 maybe) seeing as I have contact with that company that's is helping me with the forced induction side of the build, 84.5 mm pistons is what I've thought so far but want to know the benefits running smaller , should I run one external pump or 2 in tank , I also need 1250cc injectors to run e85 and make the power and q16 if necessary , not to sure why you would waste your time bashing a post , this is my first thread and I hope this is not the kind of response I have to look forward to in the future, I'm simply trying to get info from people who have experience in this power category, as for what the car is intended for , drag/show / one day my dream is shift sector with my power plant but different body that is more aerodynamic , I've got years to build this and I'm definitely not cutting corners anywhere because that's how money gets wasted people get hurt
There is lots of 700 hp builds on this site to be found most of them also have there Build info
but if u happen to check out evans tuning web site there used to be a parts chart there for selected hp levels.. It's a older parts list but it will give u some idea's, and u can get a rough estimate on what kinda cash u will be looking to spend
1250's aren't going to get you there, especially not on E85, unless you want to crank the fuel pressure up to 75 PSI, which is silly. You should be looking for 1500's bare minimum. As for the pump, check out this thread.
Just copy gringoteg's build.
And an EF isn't that light in the 91si flavor... Like 2300lbs...
Now the 88std is another animal at 1900lbs.
It's wU to the sOLdiEr!
Most if not all new comers all over look the obvious sticky above in this forum.
Moderator
68lbs/min or larger turbocharger. (This includes but is not limited to GT3584R, 6266, 6262, GTK650, S362, S366, GT3586HTA, GT3794HTA, etc)
Injectors larger that are 1200-1600cc, preferably in a Bosch-Style for better utility be it for E85 or Q16
Fuel pump in over the 400lph, but an external is easier to use than dual in-tank fuel pumps, but its up to you.
Higher volume exhaust manifold. - (take your pick of companies, Sheepey, Full-Race, Go-Autoworks, Synapse Turbo, BRMS, AFI Turbo) Use either Kooks "Ramhorns", Bottom Mounts with large single gate or twin smaller wastegates, or god-forbid even a Top Mount manifold
3" to 4" downpipe or "upipe" for exhaust system
Very good fuel management. -Either standalone management (Haltech, Motec, AEM, etc) or Hondata, MegaSquirt3 or other robust engine management.
Sleeved Block - Golden Eagle is preferred, but there still is ERL, LA, AEBS sleeves, etc to choose from.
Forged Pistons and aftermarket rods, The brands are obvious. Arias, Ross, Wiseco, JE, Pauter, Manley, Mahle, etc..
Intercooler For these levels, stick to Garrett, ETS, largest Vibrant core you can think of.
That's as good as you can get for spoon feeding. But I'm sure the OP is offended at this point not to come back.
Who is Mr Robot?
Yea my reply was solely based on the fact that we get lots of vague threads with pipe dream power goals that honestly never come to fruition, hence why we dismiss most of them
that being said, if you have the resources and are determined to finish this then we will be glad to help... while we can suggest parts for you left and right the decision rests solely on your shoulders so you need to research heavily before deciding on a certain parts combination.
Thank you to everyone who has given info so far, I have dicided to go a little over board on everything seeing as I want to have sufficient fuel and maybe a little left for the future , I've chosen 84mm pistons with 8.5:1 compression,eagle Rods, king bearings,arp top to bottom, full titanium valve train (brand unknown), cams from skunk2 (stage 3 pro series)but open to suggestions, Dorton sleeves , 2000cc injectors and a single 1000lph pump, gator axles ,10 point cage , twin disk clutch, I'm trying to stay away from using a dog box for right now ,so putting the money Into building the tranny is a must,turbo still unknown but deff going precision also wanting to do a 50-75 shot to spool this big **** cause anti-lag is not a option I'm willing to take right now , my goal as stated is 700 minimum high boost and would like 500-550 low boost but need more info to know if that's going to be an option , I'm having the intake mani and turbo mani custom made by a local fabricator who works with the high hp guys in the area, no one is really going over 450-550 b series local , so I'm kind of stuck in a area of the unknown for the local guys. As for the body, it's going in the hatch (the wife says it's a must and she's paying for half of everything) . the front end is coming from Jase Composites, still need info on hubs and suspension to put this power down, THIS BUILD WILL BE COMPLETED!!!! So please don't feel your wasting your time all info is greatly appreciated and once again ty to all who have pitched in so far.
Blakeleyr28923@hotmail.com
Gringo's formula is very similar in the area of 700whp. Some have done with 6262s some with others. Typically the SOP of parts are the following:
Also should I just hock the LS block and get a gsr due to the oil squirters or is there some way to compensate for that in the LS (girdle)? (B16 not an option)
You dont need oil squirters with forged pistons, and the added oil pressure from deleting them helps.
Man U FTW
Methinks you're right...but here's a random list of things
Sleeved/Built LS
VTEC head with springs/retainers
GSC T1 cams
T3 S366XL .70ar
ID2000cc injectors
Full Blown Dual 255 Walbro
carbon-carbon twin plate clutch
DSS Stage 3 axles
T1 cam trigger + invidual COP
Edelbrock IM + big TB
3" IC piping and Garrett/PTE large intercooler
All of this tuned on SAFC II
Sleeved/Built LS
GSC T1 cams
T3 S366XL .70ar
ID2000cc injectors
DSS Stage 3 axles
Who is Mr Robot?
And I wouldn't trust eagle rods at 700hp
Manley turbo tuff rods are the minimum I would use... at least a good set of aluminum rods or a set of pauters are needed
you can't use budget parts of any kind on a 700hp build
