7 psi do i need a harness or not? just FMU thast it?
someone is selling a kit telling me as long as i keep it under 8 psi i need to obdII to obd I conversion harness as long as I do FMU and stay under 8 psi ture or not
Re: 7 psi do i need a harness or not? just FMU thast it? (ajusaf)
If your car is OBD2 and you want to convert to OBD1 you will need a conversion harness......but with an FMU you don't need to do that.
With an FMU i would go as high as 6lbs of boost.
Hope that answered your question.
DAN
DAN
Re: 7 psi do i need a harness or not? just FMU thast it? (92civicb18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicb18b1 »</TD></TR><TR><TD CLASS="quote">You should convert to obd1 and use uberdata.</TD></TR></TABLE>
ya with programs like uberdata and hondata and chrome you can fine tune the fuel and ignition maps so your car runs like a stock turbocharged vehical. and you will be able to turn the boost up and make more reliable horsepower
Re: 7 psi do i need a harness or not? just FMU thast it? (J337_UNIT)
ok so up to 6 psi its fine with a FMU of 12;1 and stock ecu obd correct? I have a 1996 so i think i have a obd 2a. the thing is that i don't know squat about mapping etc.. if i stick to 6 psi and FMU the car can run fine as normal? Do i still have to get it dynod?
