6262 .82a/r - SPOOL?? b16A Full built
6262 .82a/r - what SPOOL?? b16A Full built
My engine:
-Valves STD Supertech
-Dual Springs Supertech
-Retainers KMS
-Cams ITR
- Intake Manifold Victor X
- Throttle body Omni Power 68mm
- IC Piping 3" stainless
- IC FMIC 31"x12"x4"
- Pistons JE 81,5mm
- Eagle Rods H-beam
- Block Guard Supertech
- Sleeves Dry Darton
- ID2000
- twin bosch 044 + walbro 255
- Hondata S300
Turbo: Precision Turbo 6262SP with .82 A/r
which the spool in a b16 that turbo6262 with .82 a / r, will happen?
Excuse my bad English, I use google translator to post ..
thanks
-Retainers KMS
-Cams ITR
- Pistons JE 81,5mm
- Eagle Rods H-beam
- ID2000
- Hondata S300
thanks
Re: 6262 .82a/r - SPOOL?? b16A Full built
my SOHC 1.6L was making 20psi around 6000rpm at its best.
now its at about 6200rpm i see 20psi. (modified the manifold and added another 10 feet of exhaust plus a muffler)
in 3rd gear.
in 3rd gear.
I do not care if you lag ... just want to know with 9300rpm rev limit, when I make the switch gear, no pressure will drop ... understand?
will be an ideal car for 1 / 4 mile, right?
I would say 6,xxx something rpm. I'm running a 6262sp ar .63 and I don't get full boost til 5,200 rpm. That's on a 84mm lsvtec mild pp built head.
I see 10psi around 6k on my 6262 w/.82 and thats on a 84mm GSR, it is a little laggy on the highway if your in 3rd and mash it, but if in 2nd its not bad
b16 to power in 6262, b18c rises so as to give out?
6262 a .82 a / r b16 81.5 mm with a boost (21 psi), with all the setup I posted above is right if properly tuned, some 480 ~ 500whp?
thanks
thanks
