5th gen prelude drag 3 ic piping help
i have a drag 3 ic piping kit for my 97 prelude, and im having trouble routing the driver side piping. does any have any pictures or how the driver side piping is routed? and does anyone know weather or not the drag 3 ic piping for my car is a/c compatible? please help me out, this is my first time installing turbo. thanks guys
Re: 5th gen prelude drag 3 ic piping help (xineedmoneyx)
it's a tight fit you will have to relocate the powersteering coolor hoses to the opening above the stock position. That's where the piping goes through... it's a tight fit...
there are two holes, the one it is currently going through and there is a hole above it, you have to bend the lines a bit and get them through the top hole... this will leave room enough for the piping through the bottom hole. it's kinda tough to bend the lines you may want to cut the hardlines and put fuel lines in their place... good luck
sure... same as this, follow it: http://www.hondaprelude.to/art....html
carburatedb18c
12-02-2004 11:50 AM
