Are 550 injectors good for 300hp??????
Old 02-23-2003, 08:39 PM
boosted_zc's Avatar
Default Are 550 injectors good for 300hp??????
My motors fully built and will be boosting around 20 psi. I was thinkin 550's for injectors, but will they be sufficient......will i need larger. Thanks
Old 02-23-2003, 08:43 PM
boostaholic's Avatar
Default Re: Are 550 injectors good for 300hp?????? (boosted_zc)
20psi to hit 300whp? What kinda small turbo are you running? 550's are plenty for 300whp. I hit 277whp and was only running 65% injector duty cycle with a 37psi base fuel pressure on some 550's.
avividmemory's Avatar
http://www.rceng.com/technical.htm#WORKSHEET
should be fine, i think 450's would even sustain 300whp...
Old 02-23-2003, 08:44 PM
ridnmyhonda's Avatar
Default Re: Are 550 injectors good for 300hp?????? (SpoolinLS)
I think 550 would be to big, 450 sound good
Old 02-23-2003, 08:51 PM
boosted_zc's Avatar
Default Re: Are 550 injectors good for 300hp?????? (boostaholic)
I'm runnin a t3/t4 on a built ZC. Base hp is around 130 and boosting at 20psi should get me about 300-330. That's my thought. Tell me if i'm wrong and why.
Old 02-23-2003, 09:08 PM
Smarter than you
DIRep972's Avatar
im running 550's and making 274whp. my base fuel pressure is stock and I have no idea what my injector duty cycle is but im sure i have plenty of room to go. 275-325whp 550cc injectors about perfect.
Old 02-23-2003, 09:13 PM
15psi of fun's Avatar
Default Re: Are 550 injectors good for 300hp?????? (DIRep)
on my friends b18c with 550cc and 15psi he dynoed 348hp his motor is fully built
Old 02-23-2003, 09:37 PM
MikeMAN's Avatar
you could probably get away with 450's but yes, 550's should serve ya fine!
Old 02-23-2003, 09:56 PM
*Boostwerks*'s Avatar
Please...
Could you go a little more indepth into your setup?
First of all I would just like to know, and second I could geusstamate what power you will be producing...
Old 03-18-2003, 06:48 PM
92HB_HB's Avatar
Default Re: Are 550 injectors good for 300hp?????? (Bryson)
okay, now where can i get a set of 550's high imp injectors?? I"m lookin to buy a new set pretty soon and need a good place to buy from...
Old 03-18-2003, 06:51 PM
MiraiZ's Avatar
Default Re: Are 550 injectors good for 300hp?????? (92HB_HB)
wow..300hp on a ZC...that is impressive!
uscivicmc
08-14-2011 09:11 AM
broadheadjohn
03-28-2007 04:20 PM
S2KP
07-02-2004 10:28 PM
graphic
04-07-2004 11:42 AM
Que_Lude
01-27-2003 02:52 PM
Quick Reply: Are 550 injectors good for 300hp??????
