500+hp guys post your fuel setups:
Hey guys, i'm looking for your high horsepower street car fuel setups. I'm in the process of a large horsepower 500-600+ street car, and just trying to see what fuel setups you guys are all running. Trying to maintain *some* streetability, to possibly daily drive my car.
Let me know what you're running, any pics, and horsepower numbers. I think this can be a good thread!
Re: 500+hp guys post your fuel setups: (Soccerking3000)
mechanical fuel pump, weldon regulator, aeromotive filter, - 6 fuel lines, 8 bosch 160lb injectors. 820 to the tires on alcohol, non intercooled
Re: (hybrdthry911)
heres mine and i drive everyday with earmuffs for the noisey pump
full race sump,aeromotive elimnator pump,-10an fed line,-6an return
Re: (swapit)
my work in process.
now is this pump that loud? also anyone else running the voltage reg for the pump? is there any down side running one without it?
Re: (Soon_2b_evil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil »</TD></TR><TR><TD CLASS="quote">my work in process.
well after i get my car running im gonna run the voltage reg, i heard they will heat up if your running it on the street often, and could burn out so it is suggested that u run the voltage regulator. what other companies offer a product like this regulator besides aeromotive?
Re: (Hybrid_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid_Coupe »</TD></TR><TR><TD CLASS="quote">620 here on One walboro 255. all stock lines.</TD></TR></TABLE>
what injector sizes and fuel pressure did u set it on??
Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">walbro 255hp pump, stock lines, precision 1000's... im a little over 500 and its approaching its safety limits id say....</TD></TR></TABLE>
i got the same setup like yours. i'm also using stock fpr. my tuner said i was max out at 400hp!!! i want to get more power
Re: (Mikey3000)
Aeromotive A1000 Pump
Aeromotive FPR
Aeromotive 100 micron filter
-8 feed
stock feed line used for return
Precision 1000cc injectors
GE fuel rail
Earl's fittings (Fast-Turbo fuel line kit)
Fuel sump welded into tank
A1000 pump sounds like a second engine.
Aeromotive FPR
-8 feed
GE fuel rail
Re: (ChrisRicketts)
AJ,
All you need bro is what I'm running!
255hp in tank, 1000cc injectors, stock FPR, stock lines.
575whp@27psi
Daily Driven!
You know what's up!
Joshua
SlowMotion Motorsports
575whp@27psi
Daily Driven!
You know what's up!
Joshua
Re: (pbsracerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbsracerx »</TD></TR><TR><TD CLASS="quote">AJ,
575whp@27psi
Daily Driven!
You know what's up!
Joshua
SlowMotion Motorsports</TD></TR></TABLE>
That is some ***** man!
575whp@27psi
Daily Driven!
You know what's up!
Joshua
Re: (pbsracerx)
575whp@27psi
Daily Driven!
You know what's up!
Joshua
I ran the same setup and it leaned out at 663 hp..im adding -8 lines another inline 255 pump and an aeromotive regulator....its all sitting here waiting on some spare time..
575whp@27psi
Daily Driven!
You know what's up!
Joshua
Re: (D@nnY)
Aeromotive A1000 Regulator
Cell 12 gallon (wish i sumped the stock tank)
-10an feed/return
-8an dual feed to rail
-6an from rail to regulator
10 micron and 100 micron aeromotive filters
going for 700whp soon
-10an feed/return
Re: (pbsracerx)
575whp@27psi
Daily Driven!
You know what's up!
Joshua
BINGO
thats the golden ticket
575whp@27psi
Daily Driven!
You know what's up!
Joshua
BINGO
