Is the 5 gen VX O2 sensor the ONLY DIY Wideband sensor option?
I know an o2 sensor from a 5gen VX will work with a DIY Wideband. Is there any other car Honda or otherwise that I could use an O2 sensor from for a DIY Wideband?
Modified by T-RO at 3:51 PM 9/26/2003 |
Re: Is the 5 gen VX O2 sensor the ONLY Wideband sensor option? (T-RO)
96 thru at least 2000 Hx uses a wideband. Im not sure if the 01+ HXs use a wideband or not.
Re: Is the 5 gen VX O2 sensor the ONLY Wideband sensor option? (HXMan)
you cant use the hx sensor with the diy wideband controlers. it has a diff calibration than the vx sensor. hell w/the cheapness of widebands now its useless to build your own using the honda sensors unless you just got one layin around.
