Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   450wp (https://honda-tech.com/forums/forced-induction-16/450wp-2620430/)
BoOstedN1ck Aug 3, 2009 03:52 PM
450wp
alright guys i know u probly heard this 1000 times but here it is again sorry. will my stock sleeves stock bore with a block gaurd carry 450whp?
StolenTeg Aug 3, 2009 03:53 PM
Re: 450wp
Stock sleeve with piston and rod will do 450whp on pump gas all day everyday
BoOstedN1ck Aug 3, 2009 03:55 PM
Re: 450wp
around what whp ware sleeves absolutly nessisary?
1sicef9 Aug 3, 2009 03:56 PM
Re: 450wp
yes, you will be fine ...throw some forged pistons and rods in that badboy and get a good tune
id say anything over 500whp is pushing it imo
BoOstedN1ck Aug 3, 2009 03:57 PM
Re: 450wp
yup i already have the pistons and rods and my hondata i was just wondering cause i want to play it safe.. thanks
1sicef9 Aug 3, 2009 04:03 PM
Re: 450wp
but what sized pistons do you have?most people that build there block bore it alittle bit over just to make sure all cylinders are perfect...so stock gsr is 81mm bore it to 81.5mm
BoOstedN1ck Aug 3, 2009 04:06 PM
Re: 450wp
well i got the block off this one guy who threw a rod and ate up the cyclinder, so hey got it resleeved with brand new ones(if it were me i would have went with some darton sleeves but he went with standard) so they are brand new cylinders
crashsvg Aug 5, 2009 04:51 AM
Re: 450wp
''Stock sleeve with piston and rod will do 450whp on pump gas all day everyday''
really? 450whp on stock sleeve?not saying its not possible but not likely to hold out ..i cracked 2 blocks 1 went @315whp the other @390whp am sleeving my next block just to be safe...
and on pump fuel? every country has a different grade of fuel as pump fuel..we get 89 some ppl get 93 lucky ppl get 100ron so it depends on where u live..
sanman000719 Aug 5, 2009 07:41 AM
Re: 450wp
I have been running a stock sleeved/stock internals gsr for a while now @24psi on E85 wich yeilded 498/322
yes it will do the power and hold it man, but you better have a good tuner
dpetro1 Aug 5, 2009 07:54 AM
Re: 450wp
1. i assume this is a b-series
2. blcokguard is not needed
3. what do you mean by standard? did he use aftermarket sleeves, can you even get replacement oem sleeves? any pics?
what turbo are you running? a small turbo at high psi could create more cylinder pressure making 450whp less safe on stock sleeves. bigger turbo and lower boost would help to reduce pressure on the sleeves.
to the guy that "cracked two blocks" what exactly happened? 315whp should be completely safe on all stock internals, sounds like a tuning problem to me.
BoOstedN1ck Aug 5, 2009 05:02 PM
Re: 450wp
ya its a b18a1 block, by standard i mean oem replacement, (waste of money if u ask me but he gave it me so i took it). the block guard is already installed. and i am going to be running a TURBONETICS T3/T4 60-1
http://i82.photobucket.com/albums/j2...onick2/4-1.jpg
UJLSMoFo Aug 5, 2009 07:09 PM
Re: 450wp
ive been running a stock sleeved b16 with mahle pistons, eagle rods and arp main studs and head studs, for 2yrs no problems. over a 100 runs on the dyno and just as many down the track. still makes 466hp and 313tq and runs mid 10's at 135mph. its all in the TUNE.....
dpetro1 Aug 6, 2009 05:41 AM
Re: 450wp
im sure you will be fine, crank the boost and have fun
BoOstedN1ck Aug 7, 2009 09:54 AM
Re: 450wp
thanks guys for the help
HiProfile Aug 7, 2009 10:01 AM
Re: 450wp
If they are Darton ductile iron replacement liners (still have alum water jacket around them), they will take quite a bit more than stock. Not exactly 100psi of boost, but more than the stock sleeves, which are brittle grey cast iron. I agree full sleeves would have been a better deal, but there can be more issues associated with them.
The main problems are tuning. An error in timing or fueling will result in damage no matter what components you use. Make sure you have good, clean parts throughout the fuel system, run a good EMS, and get someone with a stellar track record for tuning Hondas.
mynameisChris Aug 7, 2009 11:08 AM
Re: 450wp
I find that hard to believe. I'm at 328whp with all stock internals and have been for over a year and I'm fine. I have a good tune though, so maybe that's your problem?
BoOstedN1ck Aug 7, 2009 11:39 AM
Re: 450wp
Oh ya imma tune it on hondata s300. Also hey do u have any idea if golden eagle has those sleeves cause I remeber the guy who gave it to me saying somthing about that to.
redflaredcrx90 Aug 8, 2009 05:22 AM
Re: 450wp
jeff evan has made over 500 hp on a bone stock gsr more honda block will take the abuse you throw at it . tunning is always the key time and you enemy lol
