32in Hg vacuum at idle!
new to the FI community but i searched and didn't find the answer i was looking for. here is the setup:
stock b17
greddy td05h 18g turbo
greddy manifold
b&m fpr
hondata
2.25in piping
2.5in exhaust to a magnaflow muffler
in the hondata will datalogging i am registering 30-32in Hg vacuum while idling. it idle's fine at 850rpm just want to know if i should be worried. never saw any car idle at anywhere higher than 25in-Hg. i will hook up a gauge to see if the reading is consistent. any ideas on why my it is so high? n/a the motor idled at around 19.5-21in Hg. any feedback would be helpful.
stock b17
greddy manifold
b&m fpr
hondata
2.25in piping
Re: 32in Hg vacuum at idle! (88da3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88da3 »</TD></TR><TR><TD CLASS="quote">so is the high vacuum normal for a turbo car?</TD></TR></TABLE>
It doesnt matter if its boosted or na, vacuum is vacuum.. Now alot of na cars have bigger cams witch pull more vacuum at idle but the addition of a turbo doesnt change the vacuum..
And I assume that you are reading this from a map sensor.. What is your pressure reading at key on engine off?
You aren't getting a reading from your MAP sensor.
32 inHg = perfect vacuum. Unless you have an engine that came back in time from the 25th century, there is no way that is possible.
More than likely, a reading of 0 volts corresponds to 32 inHg, and you have a short somewhere.
my boost gauge shows ~18psi at 800rpm idle.
(b18c5/ itr motor that is stock except for toda spec A camshafts and greddy 18g turbo kit + fmic.)
Re: 32in Hg vacuum at idle! (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">
He is correct, and perfect vacuum is strictly theoretical and doesn't exist anywhere, not even in space. There's definitely a sensor/signal problem there.
Re: 32in Hg vacuum at idle! (Mr. Helsinki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki »</TD></TR><TR><TD CLASS="quote">
Either that or his engine has done what no scientist has been able to..
Snafu-Si
08-28-2006 04:33 PM
