300whp stock LS motor - 15psi
Well...finally got some time to take my own car to the dyno and she didnt disappoint. I was hoping for 300hp at roughly 1 Bar of boost and I made it. Next weekend is Honda Day at Englishtown (Raceway Park) and hopefully I can take that and put down some good time.
I want to thank Jeff Evans (Boosted-Hybrid) for hooking me up with some dyno time and giving me some tips to boot. Great guy! This run was done at just shy of 15psi of boost https://honda-tech.com/forums/images/smilies/emwink.gif http://nehondatuning.com/pics/xenocron300whpLS-sm.jpg Setup is: Stock B18b Motor Skunk2 Intake Manifold Hondata IM Gasket Gude Throttle Body (no idea on the diameter) Might have cams...I unno...I havent pulled the valve cover at since I got the motor. Inline Pro T3 Flanged Stainless Steel Manifold Precision SC34 T3/T04E 57 trim Turbo Tial 38mm wastegate (7psi spring) DSM 450cc Injectors JRC 30" x 6" x 2" FMIC 2.5 Aluminum Intercooler Piping 2.5" Revhard DP with 2.5" mandrel bent exhaust. 18" Resonator with Magnaflow 2.5" Muffler (this fucker is quiet) My trusty Gus Mahon Home Made Boost Controller I might be forgetting something....oh yeah, tuned by me on Crome! Did a baseline run from just my measley street tune and laid down 283whp at 13.5 psi. 1.5 psi more and some slight fuel and timing adjustments and she's purring like a kitten. |
Re: 300whp stock LS motor - 15psi (xenocron)
Damn! nice numbers man... ls power
nice numbers, keep us updated for track times.
woww nice numbers man https://honda-tech.com/forums/images/smilies/emthup.gif ...i was disappointed with my numbers. i have pretty much tha same things as you but i got a sc44 turbo at 10psi and only put down 179hp and 166tq. i have 450s, safc, turboedit, 255 fuel pump, stock b18b https://honda-tech.com/forums/images/smilies/emsad.gif
looks good Chris, congratulations https://honda-tech.com/forums/images/smilies/emthup.gif
Re: 300whp stock LS motor - 15psi (vtec'n)
good job man, bet that car is hella fun to drive https://honda-tech.com/forums/images/smilies/emthup.gif
Re: 300whp stock LS motor - 15psi (626CivicSi)
on crome pro? thanks for the cable and chip burner, work great!
good guy https://honda-tech.com/forums/images/smilies/emthup.gif |
what is your total timing at 14-15 psi? also at 11-12psi?
very good numbers btw. https://honda-tech.com/forums/images...es/emsmile.gif |
Re: 300whp stock LS motor - 15psi (95cxh22a)
Hey Chris, how's it going?
Nice numbers man https://honda-tech.com/forums/images/smilies/emthup.gif I'm still gathering up some stuff. Getting some suspension this month. Been a long hard road, but i figure this year, or next spring the LS should be boosted also. Again congrats. Let us know how those track times turn out. Oh I'd like to take a ride in it sometime. https://honda-tech.com/forums/images...s/emsmilep.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: 300whp stock LS motor - 15psi (D-t)
nice! time to update your sig https://honda-tech.com/forums/images/smilies/emwink.gif
my ls-t (in sig) made about the same numbers. i miss it https://honda-tech.com/forums/images/smilies/emsad.gif |
Re: 300whp stock LS motor - 15psi (M.A.R.C.)
Are you running the stock map sensor? Also what CC injectors are you using?
Nice #s. |
Re: 300whp stock LS motor - 15psi (Blaze45)
I run the motorola 2.5 bar MAP sensor and 450cc injectors
They are getting close to max duty cycle but Im not terribly concerned. At least this goes to show all those folks who dont believe you can make 300 on DSM 450s https://honda-tech.com/forums/images/smilies/emthup.gif Timing is about 22 degrees final. I had it as high as 26 but I wasnt making any more power..actually lost 5hp so I back it down and upped the boost from 13.5 to 15 and that brought it from 283 to over 300 that you see in that graph. This isnt my daily driver but when she's out for the week she gets raped daily. Next week at the track will be 15psi no doubt. Here's some shots from a month ago. Gotta love the sexy lines of the DA but she could use some TLC as well. Next year https://honda-tech.com/forums/images/smilies/emwink.gif http://www.nehondatuning.com/g2/engine.jpg http://www.nehondatuning.com/g2/front.jpg http://www.nehondatuning.com/g2/leftside.jpg http://www.nehondatuning.com/g2/side2.jpg And the token H-T shot... http://www.nehondatuning.com/g2/sideshot.jpg |
Re: 300whp stock LS motor - 15psi (mtber)
Hmm im gonna be running the same turbo as you and plan on running 20 psi wiht 3 inch open downpipe, wonder how much ill make...
Re: 300whp stock LS motor - 15psi (StolenTeg)
thats one hell of a sleeper https://honda-tech.com/forums/images/smilies/emthup.gif
I have a stock LS with a t03/t04 turbo .50ar, equal lenght manifold, 38mm tail wastegate (7 psi spring), 2.5 inch downpipe, 440cc injectors, hondata stage 2, walbro 255 fuel pump, msd 6 ignition, msd coil and cap, and i put down 210 whp on the dyno at 7 psi. i didnt want to push more boost because i didnt want to blow my motor, im wondering how much you think I can push and still stay reliable.
thanks. |
Re: (B18 rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 rider »</TD></TR><TR><TD CLASS="quote">I have a stock LS with a t03/t04 turbo .50ar, equal lenght manifold, 38mm tail wastegate (7 psi spring), 2.5 inch downpipe, 440cc injectors, hondata stage 2, walbro 255 fuel pump, msd 6 ignition, msd coil and cap, and i put down 210 whp on the dyno at 7 psi. i didnt want to push more boost because i didnt want to blow my motor, im wondering how much you think I can push and still stay reliable.
thanks. </TD></TR></TABLE> theres many guys on here pushing over 260whp on stock ls's. with those injectors i say u can turn the boost up to 12 -14 psi. |
Re: (B18 rider)
thanks. </TD></TR></TABLE> Daily I wouldnt push more than 10psi but if you have a nice 2 stage boost controller or an AVCR or something that is easily switchable for when you NEED it (wink wink)...as long as you are tuned for it, you are golden. And of course make sure you have more than a stock MAP sensor of course. I reall like the 2.5 Map and for the price, it can't be beat https://honda-tech.com/forums/images/smilies/emthup.gif |
12 psi with stock internal and 440 injector, I didnt think i could go that high.
Re: (B18 rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 rider »</TD></TR><TR><TD CLASS="quote">12 psi with stock internal and 440 injector, I didnt think i could go that high.</TD></TR></TABLE>
Yeah, my injectors are close to being maxed out...for safety I could up the fuel pressure and adjust accordingly, but she seemed to be purring like a little kitten in heat on the dyno. She wanted more I tell you https://honda-tech.com/forums/images...s/emsmilep.gif |
sick numbers..im in nj too...maybe ill see ya around
Re: 300whp stock LS motor - 15psi (prophetindisgize)
What fuel pump you using dude ?
BTW see you wednesday. (Low c/r sohc) |
Re: (Dr. D-Series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series »</TD></TR><TR><TD CLASS="quote">What fuel pump you using dude ?
BTW see you wednesday. (Low c/r sohc)</TD></TR></TABLE> Walbro 255 ltr/hr (not HP) See you then... https://honda-tech.com/forums/images...es/emsmile.gif |
Re: (xenocron)
Nice #'s and more important very nice powerband. Good Job https://honda-tech.com/forums/images/smilies/emthup.gif
