300-350hp limit on stock B18c1 - GTX2860r Gen II?
Hello,
I'm building a turbo kit for my stock head and block b18c1 engine. I'm aiming for between 300-350 hp tops. My emphasis is low to mid range turbo spool and power only (not high horsepower numbers), since my priority for the car is stoplight-stoplight driveability with occasional autocross. I'll be using a go auto cast turbo manifold with Hondata S300, and I plan to keep the stock GSR IM w/ IABs. Will the Garrett Gen II GTX2860r w/ .63 AR turbine housing be a good match for my power and driveability goals? Or would some other GTX variant be a better option (e.g. Gen II GTX2860r w/ .82 AR, or GTX2863r)? If the Garrett Gen II GTX2860r w/ .63 AR is a good match, is this a fair price? $1398.55 w/ 5-bolt .63 AR turbine housing. https://www.turbokits.com/Turbo_Char...ng_Turbo/6355/ TIA! |
Re: 300-350hp limit on stock B18c1 - GTX2860r Gen II?
Originally Posted by 0ptimus prime
(Post 51884687)
Hello,
I'm building a turbo kit for my stock head and block b18c1 engine. I'm aiming for between 300-350 hp tops. My emphasis is low to mid range turbo spool and power only (not high horsepower numbers), since my priority for the car is stoplight-stoplight driveability with occasional autocross. I'll be using a go auto cast turbo manifold with Hondata S300, and I plan to keep the stock GSR IM w/ IABs. Will the Garrett Gen II GTX2860r w/ .63 AR turbine housing be a good match for my power and driveability goals? Or would some other GTX variant be a better option (e.g. Gen II GTX2860r w/ .82 AR, or GTX2863r)? If the Garrett Gen II GTX2860r w/ .63 AR is a good match, is this a fair price? $1398.55 w/ 5-bolt .63 AR turbine housing. https://www.turbokits.com/Turbo_Char...ng_Turbo/6355/ TIA! Dont expect that bigger number without high knock-resistant fuel. |
Originally Posted by TheShodan
(Post 51884758)
Yes. Perfect for autocross, 280whp-300whp usable power and torque. 5 bolt turbine housing, in a .63A/R means it's in a ford-style housing and although archaic, is just fine.
(Post 51884758)
Originally Posted by Txdragon
(Post 51884815)
So there's a remarkable difference between discharge types? 5-bolt vs 4-bolt vs V-band?
(Post 51884815)
Originally Posted by Chance EG
(Post 51885197)
Also in terms of downpipe placement for people who are trying to keep certain amenities. 5 bolt or vband makes it possible to clear the AC compressor.
(Post 51885619)
:thumbup: This is why I'm going with the 5 bolt downpipe.
(Post 51886006)
At a cost of installation/maintenance headaches. (lost bolts, gasket leaks, etc)
Originally Posted by B00STD
(Post 51886021)
Can you run vband and keep A/C and PS? I thought only 5 bolt could do this?
Shodan: I haven't ordered the turbo yet, so please let me know if there is a better turbine housing option that will allow me to run a/c and p/s with a cast manifold. |
(Post 51886055)
This is what I thought as well.
Shodan: I haven't ordered the turbo yet, so please let me know if there is a better turbine housing option that will allow me to run a/c and p/s with a cast manifold. I'll PM you further information about the best way to do that, shortly |
ebay cast manifold for b series really needs the 5 bolt housing becuase it is about 1/2" shorter (pokes out less). I have a 4 bolt outlet and it wont let me use a 3" with a d series ac compressor. wish i got the 5 bolt.
https://cimg5.ibsrv.net/gimg/honda-t...6b096b1692.jpg 5 bolt 3 inch downpipe with a/c.......dual backdoor intercooler..... huge pain in ass. Not finished yet trying to find the correct way to mount the fans. |
(Post 51886640)
Really, for any exhaust manifold, if you can't do the v-band, the 4-bolt version works just fine, and allows you to change manifolds later without having to get a second turbine housing.
Originally Posted by turbociv910
(Post 51886796)
I'm using the go-autoworks cast B-series turbo manifold, and as of now, I'm on the OEM radiator. If and when I upgrade the radiator, I plan to stick with a full-size replacement.
(Post 51887501)
I'll add three things here:
1) yes that turbo will be perfect for your goals 2) get the installation kit with it. This will ensure you have the correct size oil restrictor fitting, and you definitely want to run coolant through the turbo. Standard coolant hose with hose clamps is fine to use. Just T into both heater core hoses. 3) you definitely don't need a 3" exhaust. 2.5" will work perfectly, and will allow more room around everything. I would suggest a vband housing, but there are no 2.5" vband housing options, so I say stick with the 5-bolt. Just be careful when making the downpipe for it; 5-bolt housing flanges like to warp a LOT when welding the pipe to it, and create leaks. A lot of times the flanges are actually not even flat even when brand new before welding them to anything (cough Vibrant cough cough). You may need to take the flange to a belt sander to flatten it out after it's made. And don't bother with a 5-bolt flange gasket, just use the Copper ultra high temp RTV to seal it. |
Originally Posted by motoxxxman
(Post 51888099)
(Post 51889777)
Thank you for the info! When you say installation kit, are you referencing the installation kit that is optional for the turbo in the link I posted in the first post?
Specifically here. Select the "GT" series options to work with the Gen II GTX2860R stuff Oil return line kit oil feed line - including option for "GT" restrictor option Water Cooling kit - Use the "BANJO FITTING" Option for ease of installation On a last note. There's nothing wrong with the 3" exhaust system for this turbocharger or car. Yes, 2.5" is possible, but you're not saving any money and doesn't allow you to change turbochargers should you change your mind or change your build. You'll be fine with that , even at lower boost pressures. |
Awesome, thank you!
You will want to stick with the T3 5 bolt housing when paired w/ the cast manifold...NOT a vband or 4 bolt housing when trying to retain a/c and a full length radiator. 5 bolt turbine, B compressor.
A shot of an a/c Street X kit w/ recirculated dump, GTX turbo option, catchcan, etc that was done a while ago... https://scontent.fhsv1-1.fna.fbcdn.n...2e&oe=5D4F8EC8 |
Originally Posted by Autoworks
(Post 51891829)
(Post 51892475)
Excellent, thank you! Is that full size radiator part of your kit? If not, do you sell it?
(Post 51892475)
