3 inch exhaust + short shifter?
normally id post this in the general integra forum, but i need some input.
im getting tired and aggravated at the sloppines of my stock shifter. i put energy suspension bushings in, it helped a little.
obvoiusly most short shifters were designed around a 60 mm ~ 2.5 inch exhaust, is anyone running one that doesnt interfere with their exhaust? if specifics are neccessary, its an integra with a thermal turbo exhaust.
if there was interference but it was resolved, please explain.
TIA
TIA
Re: 3 inch exhaust + short shifter? (yehiknowrite)
I was wondering the same thing. I'm about to upgrade my exhaust system to a 3" and currently have a short shifter & 2.25" piping, as of right now if I was to push down on the top of my shift ****, it'll bump up on the piping and rattle. (EM1)
Re: 3 inch exhaust + short shifter? (VspecSiR)
when they use larger piping they should also make it hang lower...simple as welding the hangers more twards the top of the pipe ....i know when i went to 2.5inch i had the same clearance between the shifter and pipe as i did with stock...the guy who did it made sure clearance was kept the same...
Who is Mr Robot?
Re: 3 inch exhaust + short shifter? (2k.civic.si)
the problem with the sloppiness is the heat from the exhaust... rubber/urethane gets hot and it gets gummy... just heat wrap the section of piping under the shifter or make a heat shield for it
Mine hits like a byatch... Had to somehow hang the exhaust lower. But now the exhaust hits every little bump!
Re: 3 inch exhaust + short shifter? (crucian)
at first when i got my 3" exhaust put on it never used to interfere with the short shifter, it was ok for months until i slammed my car and when the exhaust kept on hitting the speed bumps eventually it started making the shiter rattle and vibrate more, i really cant be bothered with it right now, but when i decide to take my anger out im going to deal with it good and proper
I have a skunk shifter and thermal 3 inch and it doesnt hit it
I had soem cheesy shifter before and it hit a 2.5 inch exhaust and one night I threw 3rd gear and the shift **** broke off and cut my hand
Re: 3 inch exhaust + short shifter? (m R g S r)
IF the piping has the correct bends around the shifter area, the exhaust should not hit it. I have short shifter and 3 inch exhaust and my car is lowered.
My exhaust only hits the ground if I go over a speed bump too fast. Its not cause I lowered the exhaust, it hugs the top of the channel in the car, its just cause the piping is large, it makes the exhaust the lowest point under the car.
I run a gsr shifter modded to fit my sohc shift linkage with es shift bushings and it feels better than any other shifter setup i've had imo. I went from the oem civic shifter, to a cheesy short shifter + es bushings, back to oem shifter with es bushings, and now this and i really like it better than any short shifter i've felt before.
cehcivic15
10
06-23-2009 03:43 PM
SPORT INJECTION
05-12-2003 07:02 AM
