3.5 or 4 inch muffler/resonators
Re: 3.5 or 4 inch muffler/resonators (nevin)
Here is the dynomax 3.5 inch muffler that I use. The exhaust is a full 3.5 inch using a dynomax bullet muffler as a resonator prior to the ultraflow you see here.
jeff
jeff
Re: 3.5 or 4 inch muffler/resonators (Bloodline)
Is that an eclipse? How do you like your exhaust setup, is it loud?
Also, does anyone know where to get 3.5" flex pipes? I found some 4", but no 3.5"
Modified by InfamousRS at 5:40 PM 3/13/2004
Re: 3.5 or 4 inch muffler/resonators (InfamousRS)
I don't know the exact brand of the muffler that is on Ralph's RX-7 but it does have a 4 inch inlet so I'll try to find out. As for the mufflers on the Civic's both Brian's and Duc's EJ6's have 4 inch exhausts which are reduced for a 3 inch inlet but it still seems to work just fine. This is a pic of Duc's rear section and as you can tell we couldn't cut off the back and weld a 4 inch core through it as it's a piece of **** Ti canister. We actually don't run flew pipes either anymore, the entire downpipe and exhaust all the way back are one piece.
EF8 D-UNIT
10-23-2006 06:02 PM
