3" ac/ps downpipe for eg with bseries - what bends?
I ma getting ready to order teh bends to make my new downpipe. It is 3" and needs to be ac/ps compatible. I dont have anything to reference and was wondering what bend i will need to make this work? I was thinking 3 180 degree bends and 1 straight, will that be enough bends? if not then what will i need?
Thanks
Thanks
Re: 3" ac/ps downpipe for eg with bseries - what bends? (turbotime)
you should only need 2 180's and one straight and dont forget a flex section
ok now my dp is MILD steel, the only flex sections are SS, can MILD be welded to SS?
Sorry i have 0 welding knowledge
other than knowing the diff between MIG and TIG
Re: (turbotime)
well how you route it et cetera will determine if it is a/c compatible, if you think the 180 bend isnt tight enough get an extra section of straight pipe and make the bend using pie-cuts
1 Post
Re: (turbotime)
Well what manifold are you using? There are very few manifolds that are fabbed up with the intent for a 3" DP to retain AC.
Unless the manifold states so... you might be using a 2.5" transitioned to 3" downpipe.
im using the revhard manifold which is really similar to the DRAG manifold as far as how it places the turbo... the manifold is ac/ps compatible
ill just get 2 180s and a straight and a flex, and since the manifold is ac/ps compatible i dont think itll be too tight to fit a 3" in whatddya think?
Re: (turbotime)
you won't be able to do it with just the bends. your gonna need to have a bunch of little pie cuts. it gonna be really tight. and one of your mount bolt will probably be really hard to get in
i think if i cut a 90 bend at 45 degrees i can prolly snake it past the ac compressor.... the draw dp was hard to get to all the bolts but it had plenty of rom clearning teh ac compressor
1 Post
Re: (turbotime)
It's gonna be rough... any manifold (unless it's stated AC Compatible w/3" DP) won't fit with a full 3" DP. Even with Pie cuts it's a huge challenge without angleing or denting the bend to clear the compressor. And at that point a 2.5" bend from the turbo may flow better than the superangled 3" DP.
If you are getting this custom fabbed you're best bet is to use a 2.5" bend and expand it to 3" as soon as you can.
Face it: you gotta pay to play... Either with your wallet or with taking out the creature features.
i hear ya!
This is getting MIG welded and tools are kinda limited, if i were to use 2.5" to clear the compressor how would i flare it out to mate with the 3"?
ill try and get a pic of the manifold and stuff on the engine so u can see how it all lays out and then u can let me know how difficult u think itll be
Re: (turbotime)
[QUOTE=turbotime]ok now my dp is MILD steel, the only flex sections are SS, can MILD be welded to SS?
Yes, you can weld mild steel to Stainless with no problem
Re: (aallbbeerrtttttt)
you should have plenty of room to run just a 180 bend, if it doesnt fit just cheat it a little its not going to make that much of a difference, but if you are **** retentive go with piecuts
chassis shops sell mandrel bends in tighter bends than sold on keteller?
i was just gonna buy the 2 180s and a straight off kteller and hope i can snake it...
yes you will be able to weld mild to stainless, it will rust though but obviously thats not a concern. just weld it with either 309L or with mig, either way it will work just fine.
you might need to pie cut a little bit there, but it shouldn't be too major, 6" is quite a bit of clearance. so long as you don't have a huge reducer sticking off the flange first.
i HAS questions ?
Re: (Turbo-charged)
Just do what I did...2.5" with a flare to 3" under the oil pan. You may have trouble/have to crush some of the tubing anyways to get the bolts on there with the 3" piece.
yeah i think im gonna have to got with 2.5"-3" flare for the first part so it flows well...
Where can i get a mild steel 2.5"-3" flare? Or if i need to get the 2.5" flared who could do it? I want it to be a clean flare...
thanks!
thanks!
