24psi on a b16 with thicker headgasket? What output?
Supposedly you can run a headgasket to lower compression by 1 full point and run 24psi on a stock b16.....
Any truth to this? ~300whp and xxxwtq.....? |
Re: 24psi on a b16 with thicker headgasket? What output? (Black R)
not on pump gas....
Re: 24psi on a b16 with thicker headgasket? What output? (dustin)
dustin ill put money i can do it with pump gas and aem ems.... hehehhe
Re: 24psi on a b16 with thicker headgasket? What output? (b18bturbo)
ahaha
you probably can. Now, get my car to start in under 5 cranks and I'd be even more impressed! |
sned me that map ill fix tonight.. ill put it my friends cars and see whats up.
My friend did it, but it only lasted for 5 seconds. HeHe!!!
Re: 24psi on a b16 with thicker headgasket? What output? (BG Boost)
I'm guessing output will be about $475+shipping for a new B16 longblock.
Re: 24psi on a b16 with thicker headgasket? What output? (NOCARLOSER)
use the blitz 3mm head gasket if you wanna do that. http://images.zeroforum.com/smile/emsmile.gif
