From 220hp B16A to 350hp, questions
From 210hp B16A to 350hp, questions
Hi, I have a Civic '94 Vti EDM B16A (hydro) with KKK T3 and stock internals, the car gives me in dyno 210hp (with 200.000km = 124.000 milles)
I want go to ~350hp (about 15psi), with forged internals, then I have think in this parts, but I have some questions:
-Block Guard: for 350hp aprox, its necessary a fluydine radiator? My radiator is the dual core from honda.
-JE Pistons / Hbeams Rods: mm The compression, what? More compression and less psi? more psi and less compression? I have think in 9.0:1 - 15psi
-Head Gasket: brand? I would buy greddy head gasket
-New Crankshaft reinforced? (124k milles), new head bolts?
-Injection: I have a 255 walbro and 440cc DSM, ok?
-More reinforce parts: I need better axles, changes the tranny? my sincros are mmm in their last days- hydraulic GSR tranny or LS?
ALso I have exedy racing clutch stageI, the T03/04E is comming, etcc
THanks & Regards
Ahhh and sorry, my english is worse, Im from Spain
Modified by ferrallas at 9:09 AM 2/8/2006
THanks & Regards
Re: From 220hp B16A to 350hp, questions (ferrallas)
block guard is not needed, those are fine rods and pistons, use a stock honda head gasket, crankshaft should be fine, step up your injectors to an RC550, GSR tranny w/lsd would be my tranny choice, I woudn't upgrade the axles until they explode-then looking into DSS stage 2 axles, that clutch will slip at those power levels-might want to try a stage 3.
310BHPB16
11-25-2004 02:19 PM
winman517
03-07-2003 12:48 PM
