)2 sensor question
ok I took out my cat and I see that I have two O2 sensors... I was going to drive my car just with the DP to the muffler shop to finish my exhaust but I only have one connection for and O2 sensor would it matter if the secondary is not connect even using the AEM EMS?
question number two I took out my resonator adn there's a vacuum hose that I disconnected from there ... what I do with it? one more http://images.honda-tech.com/set1//smile/emcrook.gif there was also another hose connected to th top of my air intake coming from the top of the block ... what I do with this one? |
Re: )2 sensor question (LJR-LUDE01)
here are some answers...
1. You will get a CEL if you drive with the O2 sensor disconnected. I am not sure what the AEM EMS will do, if it will throw a code or not. If it is like the Hondata then it wont. There are ways around it, but i am not positive yet. 2. Do not know, which resonator, the air intake resonator? 3. The value cover breather hose i am assuming what you are talking about. You can either put a filter on the value cover as many do. you can just take off the rubber hose. or you can get a connector welded onto the charge pipe or intake pipe and reroute it into there. -deepsi |
Re: )2 sensor question (DeepSi)
here are some answers... 2. Do not know, which resonator, the air intake resonator? -deepsi thanks for the others answers |
I have no clue what that is for. i never seen one on an Integra, Accord, or Civic from the installs that i have done. It might be something for the Prelude guys. You might want to ask the guys in the Prelude forum as they can probable help you faster.
-deepsi |
