15w-40 roral purple OK?
Old 09-07-2008, 08:52 AM
stockb18c's Avatar
Default 15w-40 roral purple OK?
i was think of runnin 15w-40 in my car would it be bad for the oil pump does anyone run this oil
Old 09-07-2008, 09:18 AM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Default Re: 15w-40 roral purple OK? (stockb18c)
10w-30 is what i use
Old 09-07-2008, 10:35 AM
rudebwoy's Avatar
I use castrol 5w50
I would run mobil 1 15w50 over royal purple
Old 09-07-2008, 01:01 PM
WalkerGSR1's Avatar
I ran Amsoil 5w40 when i was boosted. Kept its viscosity after a day at the track.
Old 09-07-2008, 02:50 PM
jdmdc529's Avatar
look into 15-40 rotella T as well, only $10 a gal
Old 09-07-2008, 03:05 PM
tony413's Avatar
where do you live and whats the temperature like in the winter ?
the W in th 5w, 10w, 15w, and 20w stands for winter. this number tells you the visocity for cold days. I live in florida an have the option of running pretty much 0w to 10w because its not cold here in the winter.
0W oil is tested at -31°F, a 5W at -22°F and a 10W is tested at -13°F
Old 09-07-2008, 05:39 PM
stockb18c's Avatar
i live in indiana...im just lookin for oil not to break down as much after like 1000 mile my oil look like water
Old 09-07-2008, 06:18 PM
tony413's Avatar
Default Re: (stockb18c)
whats the coldest it gets where you live ?
whats the hottest it gets where you live ?
the best GENERAL rule of thumb is.
the best oil is the oil that is changed often.
judging oil based soley on mileage is kinda the outdated way of doing things. buy a $30 oil analysis kit and send it to an oil analysis company for inspection and they will give you a full reading of the life and wear/tear of your engine.
it’s important to have oil that is thin enough to circulate easily at cold temperatures. so that means a lower "W" # as temperature gets colder. just please dont use 0W
Heavier multiviscosity oils such as 20W-40 are for high rpm, high-load applications primarily and are not for cold weather driving.
PM me if you have questions
rajasajjadahmed
Honda City
02-26-2020 04:34 AM
P-M-B,93EXsedan
03-23-2014 05:20 AM
hmonkey86
10-28-2011 12:24 AM
climb_on
07-15-2007 04:05 PM
wangutang
03-08-2006 07:10 AM
Quick Reply: 15w-40 roral purple OK?
