Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   130k+ (https://honda-tech.com/forums/forced-induction-16/130k-100818/)
Battousai TT52 Dec 12, 2001 10:40 PM
130k+
K i've got a 94 ls w/ 130k miles and counting what needs to be done so she can handle around 10 pounds daily driven??? Also w/ 10pounds on the kit bens offering what should i be looking at in the quarter ballpark times ya know??? I want to avoid a swap at all cost cause of money and dont feel like pulling the engine. thanks all help appreciated!! http://images.zeroforum.com/smile/embeer.gif
[Modified by TightTeg52, 7:41 AM 12/13/2001]
BoM Dec 12, 2001 11:41 PM
Re: 130k+ (TightTeg52)
you dont' want a swap, then REBUILD UR SHIT
DLB1994 Dec 12, 2001 11:47 PM
jinxproof99 got a a b18c1 motor in his civic engine had 140k on it and he ran 11's on a stock engine tuning is the key
D-Man Dec 13, 2001 04:02 AM
Rebuild engine with forged pistons such as arias,JE+srp,AEM and such.thats if you dont crank boost up,if you do,u need more,such as sleeves + rods.
teg90rs Dec 13, 2001 04:21 AM
Re: 130k+ (D-Man)
What other internals besides pistons and rings needs to be changed? I know it's a good idea to replace all gaskets and seals, but would I need new valves and springs, too? I plan on boosting no more than 7 lbs.
rtype11 Dec 13, 2001 07:34 AM
you can run 12's easy if compression is good, if not you will need to freshen the motor. for 10PSI you can run stock motor all day long
D-Man Dec 13, 2001 08:48 AM
Re: 130k+ (teg90rs)
Bring the Rods and Crank to a machine shop have it checked and get new crank and rod bearings,replace the rod bolts with new ones,pref from ARP.get a new oil pump too.
LoudLude Dec 13, 2001 10:29 AM
do a compression and leakdown test. This will give an idea of how your internals size up to the task. http://images.zeroforum.com/smile/star.gif
sa21199 Dec 13, 2001 04:16 PM
Re: 130k+ (LoudLude)
exactly...compression test and leakdown test should be down to see how good of condition the motor is in. Just remember you can blow up a motor with 3k miles on it just as easily as a motor with 130k. Install everything correctly and make sure the motor is getting enough fuel.
