Mikey3000 |
04-01-2006 02:58 PM |
1000cc Precision Injector o-ring problem
i'm installing these injectors on my H22A and the o-ring that seals the injector in the fuel rail always rip on me when i try to install them. the green o-rings that came with precision were much worse than the stock o-rings. i got one o-ring on w/o ripping it so it is the only one that is sealing well and not leaking fuel. when i installed them, i put oil on the outside of the o-ring to try to get it in w/o ripping but to no avail. my question(s) is/are: is it ok to use factory o-rings with these injectors? any tips or advice on getting the injector in the rail w/o them ripping other than use oil? thanks.
