1000cc injector question.
Ok here is the deal, im planning on making 300-380hp on 1000cc injectors.
and im running a gt35R turbo with 3indownpipe and later in the future is planning to go bigger with better internals and more boost. Just want to buy it and run it now so i won't have to switch it out later... |
Re: 1000cc injector question.
And your question is................................................ ....?
exactly
if its can i make that power on them then yes yes you can |
oh yea the question was, Can i run the 1000cc and be fine or is it too big???
If you question is "Can I make 300-380whp with 1000cc injectors?" The answer is yes.
You can achieve that on pump gas or e85. Depending on your plans for "going bigger" you may need more injector in the future. My Injector Dynamics 1000's maxed out at 521whp on e85. |
yea just planning to run it on pump gas, but i also heard that running it e85 would be safer because it cools down the cylinders?
wow must be a pumpm issue because ive made 650 on rc1000's and e85 the 1000's are fine man, and will give you the opertunity to make more power in the future |
Interesting.. It may be pump related because I'm running an a1000 and they dont like high base pressures. I just went ahead and bought ID2000's :thumbup:
thanks guys.
umm im on an a1000 at 70psi base man been like that for 3 years.
is this what your being told or just think out of caution |
OP no problem man
interesting...sanman000719 what pump was u running and fuel pressure?
a1000/rc1000/e85/base was 70psi its maxed out now at 600, and duty is 98%
hmm wonder what i can do on pte 1200 and walbro 255 or or walbro 400 on the e85
Originally Posted by sanman000719
(Post 46646172)
is this what your being told or just think out of caution I was suprised that they ran out of fuel so fast myself since I had seen people making 600 on ethanol. |
Originally Posted by rico892002
(Post 46646384)
Btw, I thought you were running (2) 255's? |
| All times are GMT -8. The time now is 07:33 AM. |
