10:8 compression ok for dd turbo?
I plan On getting a set of arias 84mm flat top piston, but the compression they have for my application will be 10:8(gsr 84mm). Just wondering if this will be ok. I had 9:2 before and since a rebuilt needed and i wanted to try somthing with higher compression. I wanted at least 10flat compression, but the closes was 10:8. Arias piston brand is what I'm only trying to get. Im trying to make around 500-550hp on e85 or pump 91. Meth Injection can be used if needed for pump gas.
Re: 10:8 compression ok for dd turbo?
You mean 10.8:1 and 9.2:1 correct?
You'll be okay with 10.8:1 and E85 is too debatable of a topic to even get started.
I have NEVER seen a thread pop up where someone using e85 got a bad batch of gas and blew they're motor.. NEVER! ALWAYS A BUNCH OF HE SAID SHE SAID BS..
If e85 was so inconsistant why do they produce flex fuel vehicles?? Don't listen to the haters ^^^
Run e85 and save your motor.
Yes, I didn't want to be too technical. I was sure everyone here knows. I guess I will look into getting the flat top 10:8:1 pistons.
they should be around a -3cc piston. I have a set of flat top Wiseco's for my 84mm LS. Im using a P8R head with the 47cc chamber, so I get a final CR of around 10:1 flat.
What head are you using?
You can also go with a thicker HG if you want to drop the CR a bit.
E85 is the way to go especially if you have gas stations with pumps in your area..
EK9
" Compression ratio is the ratio of cylinder volume with the piston in the bottom of the bore divided by the cylinder volume with the piston at the top of the bore.When you bore the cylinder it's volume is larger. Your volume increases when the piston is at the bottom of the bore a lot more than it increases with the pistion at the top of the bore. If the piston comes to deck height or higher then the volume with the piston at the top of the bore does not increase, but the volume with the piston at the bottom is larger. That makes the compression ratio higher with a bored cylinder."
Also if you use a compression calculator for an engine and change nothing but the bore, the compression does go up
'' Compression ratio is the volume of the cylinder when the piston is at the bottom of the cylinder compared to where it is when the piston is at TDC. A 100 cubic inch cylinder would have its volume squeezed into 10 cubic inches with a 10:1 ratio. The easiest way to keep track of it is to think of every thing as volumes that are stacked on top of one another. The factors that stack up are the displacement of the cylinder (bore and stroke), the volume of the deck clearance (getting back to the zero-deck issue from before), the volume of the gasket (which is basically a short-round cylinder), and the volume of the combustion chamber. The net combustion chamber volume means you must subtract dome volume add the dish volume. Use the formula (bore x bore x stroke x .7854 x 16.4) to get the volume for a cylinder in cc's. Stack up the cylinder + the deck volume + the gasket volume + the net chamber volume---take this number and call it A…Stack up the deck, the gasket, and the net chamber volume and call it B….. Take the big number A and divide it by the small number B and it will give you the compression ratio.''
LSEGHATCH
10-06-2004 07:44 PM
