10.50 lsv set up , bitch wont start
hey guys,im having trouble starting this new build
my set up is
b18b block
ls crank
eagle h beam rods
cp 9:1 pistons
acl race bearings
obd1 gsr head
supertech dished valves
supertech springs and retainers, valve guides
gsr cams
blackworks cam gears
edlebrock manifold
turbo set up
blueridge motorsports top mount
borg warner s300
tial 44 mvr
full race ic
fuel setup
id 1000s
aeromotive 340 stealth pump
aeromotive fuel filter
aeromotive fpr
aem fuel rail
ems
hondata s300 with boost option
im getting spark,im getting fuel, did a compression test and fot 150 psi on all 4 cylinders with no leaking compression, i swapped map sensor, distributors and still nothing, car cranks and feels like it wants to start for a quick 2 seconds and then it keeps cranking with no feeling of wanting to start, car has a brand new optima battery and i had already downloaded a base map from xenocron to my s300, i have the map sensor and all sensors plugged in right and i have 4 grounds on the car, the battery,valve cover,thermostat housing,and trans housing. any ideas will help thanks
my set up is
b18b block
ls crank
eagle h beam rods
cp 9:1 pistons
acl race bearings
obd1 gsr head
gsr cams
edlebrock manifold
turbo set up
borg warner s300
tial 44 mvr
full race ic
fuel setup
id 1000s
aeromotive fpr
aem fuel rail
ems
Guest
Posts: n/a
Re: 10.50 lsv set up , bitch wont start
If spark timing is close, and mechanical timing is spot on, one could only assume the corrections/offsets aren't setup properly. Most likely it is flooding if you are POSITIVE ALL other aspects are CORRECT. Have you tried to vary the throttle open while cranking to see if it tries to start? I would throw a fresh set of plugs in either way. Have you made sure your fuel pressure is correct as well?
fuel pressure is around 40 psi , yes firing order is right , ive tried to start it with the throtthle open and still nothing, ill post a video soon
Make sure the battery has a good charge check the battery under a load.
what map sensor 3 bar? maybe the seting for the specific map sensor is off. Hook up a laptop and check the settings on your s300.
Since your running 1000cc you might have to pull alot of fuel to get it to start
raverx3m
Engine Management and Tuning
09-30-2013 07:04 PM
racin_jayson
09-05-2007 12:53 PM
