07CivicMD Build Thread and Glance at Swift Racing Turbo kit
I wanted to create a new thread so I can post the latest PICs and information on my engine build and a glance of the Swift Turbo kit. The engine is complete and installed minus the wiring. All the pipe, exhaust and exhaust manifold fabrication is 98% complete. *Note that all the parts you see in on the car may or may not be available for the production kit. The exhaust is placed along with the downpipe and wastegate. Over the next few weeks the Haltech, gauges, boost controller, wideband and Fuel system will be installed. More PICs once those parts are installed.
This has been a pleasure to work with Mo at Swift Racing on this long process. I’ve learned so much over the course of tearing and building up the K20Z3. Cars has always been a passion and finally had the opportunity to create a unique car. I have always been a Mustang person since I was 14 and owned approximately 19 since that time. This is my first attempt in the ricer market and hope that this build can answer some of those nagging questions and over time someone can take this build one step further.
Engine Build Details:
Darton Sleeved Block (88mm bore resulting in a displacement of 2092.3cc vice the stock bore of 86mm and displacement of 1998.3cc) racing block.
Wesico Pistons (9:1 compression)
1260cc Injectors -
Carillo Rods
Modified Stock Oil Pump
ACL Racing Bearings
Cosmetic Gaskets and Seals
Modified stock Oil Pan
ARP Head Studs
Custom Tubular Exhaust Manifold
Snow Methanol Injection
Haltech E8v2
Custom Head Work - Stage 3 port (Decked and possible dropping compression to 8.75)
Carrillo Springs, retainers and valves (1mm oversized).
Swift Custom Intake *later this year. The intake will have custom fuel rail and billet runners.
Brian Crowler Stage 2 - turbo cams
Oil Stuff:
Swift Custom Oil Setup
Electronics Stuff:
Blitz Boost Controller
Blitz Turbo Timer
Innovate XD-16 wideband gauge
AiM MXL Strada wired to Haltech for instrument cluster for oil pressure, cooling temp, RPM and etc.
Fuel Return Stuff:
Swift Racing Custom Fuel Rails - with stock intake; the purchase of a Inline Pro Fuel Rail.
Braided Fuel lines with return setup
Swift Racing Technologies - Home
SRT Spec'd 6776E Series Precision Turbo.
TiAL 38mm Wastegate
TiAL BOV
Stainless Steel braided oil supply line with SRT exclusive oil supply tee. High Temp oil drain line
4" High flow lifetime cone filter
5Bar Map Sensor
Dual Walbro® 255lph High Pressure intank fuel pump
All Mandrel bent FULL POLISHED aluminum intercooler piping w/bead rolled ends
Custom Front Mount Intercooler rated at 650+HP
18-20PSI Maximum Boost Pump Gas - 22-24PSI on Methanol – Race tune later this year
Stainless Steel High Grade clamps
NGK Performance Iridium Spark Plugs, 1 step colder
3" Mandrel bent T304 SS race downpipe
3" Mandrel bent T304 SS front midpipe
Other Stuff:
Tein Coilovers Basics
Carbonetics - Double Carbon Clutch
Stock Engine mounts - Upgraded polyutherane
Custom braking
P2R throttle Body Gasket
Custom 3" Swift Exhaust system!
TL Type-S rims
1260cc Injectors -
Carillo Rods
ACL Racing Bearings
ARP Head Studs
Haltech E8v2
Oil Stuff:
Electronics Stuff:
Blitz Turbo Timer
Fuel Return Stuff:
TiAL 38mm Wastegate
TiAL BOV
5Bar Map Sensor
Other Stuff:
Custom braking
TL Type-S rims
Darton East K20 Sleeved Block
Stock Crank (Balanced)
Pistons are installed. Leak tested and holding 9.0:1 compression with no leaks. 88mm bore resulting in a displacement of 2092.3cc.
The Stock Oil pump was modified to increase the oil flow. Pockets where placed on the block underneath the oil pump to help with decavation.
Swift Racing Stage 3 Race port. The stock Honda heads are amazling huge. I wish I had closer PICs of the port but there are smooth and very sharp on the inside. Amazing port job!! And done by hand!
I planned to use Ferrera Valve train to complete the head. Spring, titanium retainer and 1mm oversize valves. Too bad it will only look like this before startup!
The head passed the leak down test with no leaks and after being decked the compression has dropped to 8.75:1 compression.
As you can see the motor is back in the car. I forgot to take PICs of the CAMS before they were installed so I hope these PICs will do them justice. BC Stage 2 Turbo CAMS.
Final assembly of the Exhaust Manifold before the engine is place back in the car for good.
Engine Dampner
Finally back in the car for good!
Quick Glance of the turbo and intercooler piping
The heart of the build. Precision PT6776E T3 turbo!
Bottom View of the Turbo.
Engine Dampner
Swift Racing Custom Tubular Turbo Exhaust Manifold. I have several angles below
TiAL wastegate and placement with the Exhaust Manifold. Talk about a tight fit.
Quick Glance at the intercooler piping for the Swift Kit. Still waiting on the TiAL BOV so more PICs to come.
Kept my front bumper support and no modifying required! Good for 650WHP+
Re: (07CivicMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07CivicMD »</TD></TR><TR><TD CLASS="quote">Notice the Dump Tube that runs in tandom with the exhaust downpipe!
Also notice the shifter cables (Pretty sure thats what the two black cables are) because they will probably melt soon
07CivicMD
Honda Civic (2006 - 2015)
41
06-06-2010 09:30 AM
