@%$#*&!! flywheel bolts!
Guest
Posts: n/a
Holy sheeeit those ******* were on tight. I put a propane torch to them, soaked them in liquid wrench overnight, pounded on them with a hammer , and used a big *** breaker bar and still almost herniated myself trying to get them off. Plus I rounded the corners on those 12 point motha' ******.
OK, now that I got that off my chest, the question. Should I put hi temp grease or anti seize on those things before I reinstall the flywheel or is it better to leave then dry and have more friction to prevent them from loosening up?
Re: @%$#*&!! flywheel bolts! (zcivic91)
you might want to put a little on
my buddys prelude had 3 back themselves out, 1 fell out and destroied the clutch. the other 2 were sanded smooth by the clutch disc.
Re: @%$#*&!! flywheel bolts! (filetofit)
it is recommended to use loctite on those flywheel bolts and torque them to spec. everytime i do this i have NO problems taking them back off, i speak from experience.... lots of it.
Re: @%$#*&!! flywheel bolts! (GudeH23a)
Re: @%$#*&!! flywheel bolts! (boostaholic)
that makes me feel crappy, cuz i read that they can come out so we used loctite. the red one. DAMNIT! will they be that hard to remove?
Juan_Mitosis
60
05-20-2016 07:20 AM
