**OFFICIAL FORCED INDUCTION RANDOM CHAT THREAD**
#3676
Who is Mr Robot?
Re: **OFFICIAL FORCED INDUCTION RANDOM CHAT THREAD**
I literally can't catch a break... turbocharger thrust bearing on the dart has failed already. I've barely had the car a week and haven't even touched it. plus dodge is trying to say that even though the turbocharger is covered under the power train warranty on paper it might not actually be covered in real life. luckily the dealer I bought it from has there own little warranty deal.
I need a vacation
I need a vacation
#3677
Good evening gentlemen! I hope LightningTeg can chime in since I know he recently switched turbo manifolds. Though I'm open to any advice/discussing options.
I am trying to make my setup even more responsive, looking to switch from my Full-Race T3 Topmount to possibly a mini ram manifold. Though I came across a thread about few years ago when Full Race tested a Ramhorn vs Topmount and they stated the Topmount spooled the turbo just as fast and actually picked up some midrange. Don't know how much truth is in the testing or just marketing to help sell Topmounts :p.
setup is
84x87mm GSR
Laskey Head with valve job
ITR cams with Supertech valvetrain
Skunk2 Pro Series IM/ stock TB
Precision 600hp IC
Full-race T3 topmount/with 44mm Tial WG
Garrett GT3037R . 63 housing with Full-race 4" Downpipe
Tuned on S300
Car runs mostly on 93 pump
Car made 435whp and 278trq on 16psi 93 pump
523whp and 362trq on C16
Worth switching manifolds or just over thinking the setup.
setup is
84x87mm GSR
Precision 600hp IC
Tuned on S300
#3678
Moderator
setup is
84x87mm GSR
Precision 600hp IC
Tuned on S300
setup is
84x87mm GSR
Precision 600hp IC
Tuned on S300
A mini-ram, & kiwi styled manifolds for that turbo.
Not much more to discuss, really. Unless you have a turbo over 65lbs/min looking to only drag race the car, the top mount is a waste of time
#3679
the full race comparison was a ram horn vs log and is somewhat debatable but is shows slightly longer spool and more power on the top end which does make since, only possibility is they somehow made the spool time look less then it was in real life via tunning /dyno.
Here is the original post
#3680
We've unhinged FULL-RACE's test with actual utility on the street & circuit beyond the dyno years ago.
#3681
https://www.youtube.com/watch?v=bFjuBEUE-qg
https://honda-tech.com/forums/forced...gt35r-1515492/
#3682
yea I beleive that the pic and video were from that post I forget where i found the image it took some deep searching so I saved it.
well that was from 10 years ago so manifold options were not like what we have now. Im with shodan on this tho mini ram for more responsiveness or ram horn for slightly more power up top
#3685
Optima batteries were a lot better when they were still made in the USA, after they started production in Mexico there batteries went to crap. It wasn't uncommon to get 8+ years of service out of the old USA production optima batteries.
#3686
What other batteries should i look into? I picked this one to help with the amp draw the spal fan pull.
My idle doesnt drop as bad as the last battery
#3688
are you running alot of electronics? my run of the mill battery works fine for me, and yes I have a sound system chinese amp overated at 1600W powering 2 12"s. I did get a rebuilt alt off ebay from some mexican guy supposed to be 90A seemed to work pretty good
#3689
Started tuning this stock ls motor and messed with timing down low during spool up
I took out about 3 degrees of timing from 2100-2800 rpm and made about 2psi more boost. afr got richer so I still need to lean it out a bit.
#3690
patchy,... whats good.
what happened to the b20v setup. AND that mini ram you made. didnt last long enough to get final pics up
#3693
#3695
Been a long time since I've been on HT haha. I know this is the FI section but I always get a lot better info than some of the others (and I do have plans on going boost)
anyways, I need to put a different head on my car. I've been running this worn out stock head for 3 years now and it's got a totally trashed guide on cylinder 1 and it smokes like a damn freight train.
So I decided to freshen up my ported head now that I know i can just run stock retainers on the dual springs it has. It got me wondering though about the port job that's done on it.
It's an LS head, but I was wondering what you guys thought of the port work. I'm tempted to hit it with like, 80 grit to get back some texture on the runners since they're all smoothed.
These are pics of the intake and exhaust ports, as well as stock ports for comparison.
#3696
Quick question.. I have a f20b.. overbored to 86mm with bismoto 11.0-1 forged pistons arp bolts and studs blox dual springs/ti retainers skunk2 stage 2 camshafts hks cams skunk2 70mm tb fierra high compression valves with a 3 angle job..no porting on the head.. but the intake manifold (stock) has been gutted.. she is ready for a turbo.. but I don't know what size is best.. I have a comptech head gasket. She makes 179hp (made 218hp) now chipped and tuned on neptune (Matt shue) realistically I'm shooting for a reliable 350-370 hp and about 280 torque VTech hits at 5500.. I have a 2.25 straight exhaust. I'd like my turbo to kick in right about when my VTech hits.. for that jetpack feel... But save me a ton on gas when I drive normally. Also I have precision turbo 440 wide angle injectors (straight off a mustang I believe) currently running at less then 60% saturation.
#3698
Honestly it depends on your budget. but for that power goal a simple 57 trim T3/T04e turbo would work good. It'll kick in before 5500rpm I'm sure (I don't think you'd ever want a turbo that spooled THAT late. that's just horrible for your power under the curve) but the 57 trim is probably the most ideal turbo for your power goals. Maybe not most ideal, but definitely a very easy to reach with that turbo without having to run a lot of boost.
#3699
Anyone with experience switching to a larger intake manifold? Im planning to build my block over the winter and turn the boost way up. Im toying with the idea of getting rid of the stock H23A1 intake manifold and picking up the (beautiful) Golden Eagle manifold. I believe it is right about double the plenum volume of my current manifold and im concerned that it would hurt the responsiveness of the turbo having to fill that big plenum up before i can build positive pressure. I dont really want to trade torque/power under the curve for top end hp.
experience/opinions?
#3700
With intake manifolds they shift powerband, big plenum, short runner, power shifts up high. Smaller plenum, longer runners shift the power down to the mid range. An intake manifold like that would push power up high while one like a skunk 2 would keep power in the midrange like you want.
