**16G killer????**
**16G killer????**
hey everyone!
i have a tdo4h 15g turbo on my b18b right now....its toooo small for me feels like it runs out of breath after like 4000 PRM, i always hear about the 16g killer that the turbo eclipse guys upgrade too...... will the 16g bolt up to the 15g (sohc) greddy turbo manifold?? i knw the mitsu and greddy stuff is the same..... will this be big enough for a LS motor??? how much do they run?? where can i get one???
thanks for the help!!!
Re: **16G killer????** (boostinb18)
the 16g killer will basically bolt up. Normally the DSMS move from the t25 to either the 16g killer or the 20g. You could go with the 18G...that turbo is pretty much good for up to around 300-400 HP. In anycase the 16G's can be bought here...http://www.turbochargers.com/currentspecials.htm.
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
if you want a used super 16g that's ported and clipped, i have a friend selling one. he had it on his gst and it ran 11's. he sold it and now has a hatch with nitrous. i can find out the price for you if you want. should be in good shape cuz he babies all his race cars. let me know and i can give you his contacts info.
Re: **16G killer????** (not so civic)
i wanted the 18 g but it doenst bolt up to the 15g manifold....thats why i want the 16g cause i can use the same manifold, yah im interested in your friends 16g ported.....how much does he want for it??? will it bolt up to my manifold and down pipe?? and will it run well eith my motor????
thanks!
thanks!
Re: **16G killer????** (bretx0r)
it is thesame bolt pattern as a T25?? how much does one of those run?? better then a 16g?
I really want something bigger then my 15g it just sux HIGH END!!
but it does spool hella fast....but theres maddddddddd drop off after like 4500-5000 RPM.
thanks
thanks
I believe its just a "big" 16G
They normaly use a DSM 14B, and just machine the hell out of it....put bigger trim and port the housings.
[Modified by Bryson, 12:44 AM 8/11/2002]
Duck Sauce
07-06-2004 06:51 AM
VSM EXtasy
02-25-2003 11:47 AM
