***Official F22B Turbo Thread***
#976
Premium Member
Re: ***Official F22B Turbo Thread***
Generally it's going to depend on your manifold and turbo setup. I usually go for the driver's side of the pan. Just make sure it's not installed too high because it'll interfere with the windage tray and/or girdle which will cause drainage issues. Also no kinks and the actual fitting on the pan should be the lowest point in the line.
#979
might as well add my turd to the list.
9:1 aries piston 86mm
rods say scat on the bolts assuming they are scat. came with the bisi piston/rod combo
cnc werx cylinder support system
arp studs
oem head gasket
bisi pro race springs
bisi lvl 1.2 cam
1000cc rc injectors
h23 plenum f22a6 runners
action clutch
gen one dsm manifold
and a tiny evo3 16g turbo. at its max
350hp 298 tq and a heart breaker dyno
What psi were you running to achieve those numbers on a 16g?
#980
I did a search and didn't really find a thread to all the f22 turbo's out there.
Post your specs and pics if you got them. Wanna see how many people are rockin the f22!
I guess I'll start the thread.
I got a 96 Prelude:
Stock Head/Block
Turbonetics Turbo Kit T3/T4 at 9psi
Competition Clutch Stage 4
8lb Lightened Flywheel
So far my best time on the track has been a 14.5 at 96mph.
Haven't dynoed it at 9psi but at 5psi I put down 185whp and 205wtq.
Here is a quick pic that I took awhile back.
I got a 96 Prelude:
Stock Head/Block
#981
