***89 PSI ToO much Oil Pressure???***
OK i just installed my blox oil temp and oil pressure gauge.
I have a b16a with 9-1 compression and eagle rods and i'm running Mobil 1 10-W-30, under normal drving it sits around 60psi then once its alittle harder than normal driving it jumps to 75-80 and then when i'm boosting alittle bit like 3/4 because its not fully tuned it jumps to 89Psi is that to much?
Also my oil temp is around 210 F and then sometimes 225 on a decently hot day
Thanx for the help guys going to get it tuned in 8 days just want to make sure nothing breaks thanx
Re: ***89 PSI ToO much Oil Pressure???*** (White Smoke)
Thanx man yeah i was reading up on it and supposidly some one said i could blow my oil seal on my turbo if its that high any other opinions thanx guys
Re: ***89 PSI ToO much Oil Pressure???*** (spoolingb20)
Yea, make sure your turbo has a built in restrictor. If not you need to get one from someone like atp-turbo.com
Also it is a good idea to run an inline oil filter. I got one from summit. I made a thread not long ago and someone pointed out the one I ended up getting.
Location: That's the wrong tone... I'm Skunk2 certified.
here's the link to sp00led's thread:
https://honda-tech.com/zerothread?id=1952490
is the filter media reusable? have you noticed it picking up anything?
Re: ***89 PSI ToO much Oil Pressure???*** (Themouse)
89 psi isn't bad at all.
Under WOT my friend's gsx gets to like 100, its funny watching it peg at the end of the gauge
Re: ***89 PSI ToO much Oil Pressure???*** (awdgsx96)
Thanx for all the help guys yeah i have the greddy 18g turbo and i have no idea if it has a built in restrictor or not so if anyone could help out with that that would be great thanx
Getting it tuned on the 16th hopefully it works for my b-day on the 18th
Re: (Topdawgg)
yeah i'm definitaly going to get one i just want to get it tuned first cuz that all i have money for and then i'll by the restrictor thanx guys
i ♥ my honda
Global Mod
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Themouse »</TD></TR><TR><TD CLASS="quote">Thanx for all the help guys yeah i have the greddy 18g turbo and i have no idea if it has a built in restrictor </TD></TR></TABLE>
Pretty dam sure (99.5%) it has one built in. You do not need to add another on.
thanx for the help white smoke yeah i'll look into it more but yeah i think my turbo would have been shot by now if i didn't have a restrictor
xkrazyxjbrkerx75
08-09-2011 02:47 PM
greasemonkee
08-25-2007 03:46 PM
