$3800 to spend, buy pre-fab kit or piece together?
Old 10-20-2004, 07:37 PM
Hatchbizzack's Avatar
Default $3800 to spend, buy pre-fab kit or piece together?
I'm really at a crossroads right now as far as modding my engine and I did some thinking with my friends today. By saving the money I would spend on expensive intakes and manifolds, I would actually have enough to turbo my car.
I have been looking into different kits and I've began to be fond of the Lovefab manifold and the various Precision turbos. I feel like for the amount of boost I want to run that a larger turbo and equal length manifold will make more power until I can afford an engine build.
There are some deals running on the RevHard kits where I can drop $3250 and get a Stage 2 Revhard kit with Hondata S200B, 440 or 550 Rc's, and boost gauge. I would rather piece together my own kit, but which would be better for the money I have?
If anyone thinks that I should piece together my own kit, make suggestions on parts and things. The engine is a stock internal b20/vtec with the exception of ARP rod bolts, head studs and a Golden Eagle headgasket. I don't even plan on running anything more than 10 psi, but I would like to make some power when doing it.
So, any help at all would be greatly appreciated. I don't want to blow anything up haha. Thanks guys.
Zach
Old 10-20-2004, 07:38 PM
m R g S r's Avatar
Default Re: $3800 to spend, buy pre-fab kit or piece together? (Hatchbizzack)
Piece it together, or PM FullRace Henry, they will deff. hook you up.
Old 10-20-2004, 07:44 PM
O.G. triple O.G.
NVturbo's Avatar
Piece it together. YOU GET WHAT YOU WANT INSTEAD OF WHAT THEY GIVE YOU IN A TURBO KIT SYSTEM. Plus, for just the same amount of money... you can actually get a larger turbine, bigger FMIC, a nicer wastegate, and still have enough left for other components.
Old 10-20-2004, 08:18 PM
NotUrAvgSi's Avatar
Full-Race kit. Their IC setup is freaking awsome you only have to run 2 charge pipes because of the back door intercooler.
Old 10-20-2004, 08:20 PM
OG triple OG
ATS*Mark's Avatar
Default Re: (NotUrAvgSi)
the full race kits are like your favorite pieced together kits lol...they are the ****. but dont buy a greddy or the like kind of kit....piece it.
Old 10-20-2004, 08:35 PM
Default Re: (Hella_JDM)
But is it even possible to get a Full Race kit for 3800 dollars? Last time I checked, those kits were like... 4k+. I guess I will have to check the website.
Thanks for the suggestions so far guys, keep them coming. I need all the opinions I can get!
Old 10-20-2004, 08:40 PM
NotUrAvgSi's Avatar
non a/c is like $3500 for stage 1
Old 10-20-2004, 09:02 PM
Alchemist's Avatar
piece it together
Old 10-20-2004, 09:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotUrAvgSi &raquo;</TD></TR><TR><TD CLASS="quote">non a/c is like $3500 for stage 1 </TD></TR></TABLE>
ok, so I just found out that the stage 2 goes for less than what I have to spend so I'm pretty sure that's what we'll be goin with.
Does anyone have any experience with Full Race kits?
Old 10-20-2004, 09:31 PM
The Boot
Smokinsax's Avatar
Default Re: (Hatchbizzack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchbizzack &raquo;</TD></TR><TR><TD CLASS="quote">ok, so I just found out that the stage 2 goes for less than what I have to spend so I'm pretty sure that's what we'll be goin with.
Old 10-20-2004, 09:55 PM
i HAS questions ?
.dave's Avatar
Default Re: (Smokinsax)
What're you planning on doing for fuel/timing?
Old 10-21-2004, 04:30 AM
junkyard racer's Avatar
Default Re: (d@ve.G)
im building my full D series engine, no sleeves, with turbo for about $2500 should be around 350whp when its all said and done
Old 10-21-2004, 07:36 AM
mchuang's Avatar
Put it together yourself you will save more money
Old 10-21-2004, 07:50 AM
DaX
DaX's Avatar
As always...unless you plan on buying a Full-Race kit, I would piece your own together. This is merely my opinion though.
Old 10-21-2004, 09:02 AM
RyanEJ8's Avatar
Default Re: (mchuang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang &raquo;</TD></TR><TR><TD CLASS="quote">Put it together yourself you will save more money</TD></TR></TABLE>
Old 10-21-2004, 09:19 AM
m R g S r's Avatar
I spent about that on my pieced together kit. But it wasn't like taking the hit all at once, I bought the parts over time, and borrowed money from my mom lol.
So if you have the $$ lying around, just go spend it with full-race, and on engine managment/tuning.
Old 10-21-2004, 09:21 AM
Race Egr's Avatar
Default Re: (RyanCivic2000)
FULL-RACE
Old 10-21-2004, 10:17 AM
project dc2's Avatar
Default Re: (NAPIER)
piece it together with quality parts.
Cestparti
07-02-2010 06:45 PM
WanderingSamurai830
22
05-07-2007 02:19 PM
SpoolnEG6
10-20-2005 02:07 PM
Ls-Turbo
08-30-2005 10:34 AM
bigblockEG
01-25-2003 08:15 PM
Quick Reply: $3800 to spend, buy pre-fab kit or piece together?
