plug and play built b series swap
COMPLETE PLUG AND PLAY SWAP BUILT FOR BOOST (NEVER SAW BOOST, ABOUT 8K Miles on build)
B16A2 Block Darton OEM replacment sleeves (stock tensile strength is 30,000) These liners are (100,000) Eagle Rods CP Pistons (82MM) ACL Bearings Fully rotated and balanced to 12k rpms Comp Flywheel Comp Stage 3 Clutch CTR B16B Head CTR Cams Cometic Valve Seals Supertech Valve Springs and Titanium Retainers Endyn Timing Belt Tensioner Skunk 2 Intake Manifold (First Gen) ITR Header (has cracks) (was a temp header, never went boost) JDM GSR Transmission 3rd gear synchro is starting to go, starting to grind Hasport Mounts for EK Axles 99-00 OBD2B to OBD1 Jumper Harness Chipped P28 (Phearable Basemap) Oil pan is tapped for boost. Also running ls vtec line kit with greddy sandwich plate. Motor is in the car, I drive my car 2-3 times a week. Will drop pan and pull valve cover for serious buyer. There are a few issues I will also disclose to serious buyer. I am sure there are a few things I am missing. https://cimg0.ibsrv.net/gimg/honda-t...64e2f60603.jpg More pics upon request. |
