2007 Honda Civic Si Sedan 640HP Fully Built
2007 Honda Civic Si Sedan 640HP Fully Built 12000FIRM
Hi Honda Tech!
This is my Turbocharged 2007 Honda Civic Si Sedan. Vehicle is just over of 104,000 miles. 6 Spd. Manual Transmission. Two Owner, I purchased it new from the Dealership I work in. Vehicle is in good shape has a few dents, few scratches, normal wear and tear for a daily driven 103,000 mile street car. Oil has been changed every 2 months or 2000 miles and has been rigorously maintained throughout its life. I am a car guy ; I have spent a lot of time, energy & money to build this car. The car is Turbocharged with a fully built motor top & bottom. Car makes over 640WHP @ 20PSI on E85 gas. I'm asking $12000 FIRM. No Low Ballers, no Joy Riders. Transmission was just Rebuilt along with a large list of other items, all OEM parts. Car needs NOTHING. Not in a terrible hurry to sell car, Car has a long list of modifications, please contact me if you would like more information. . .
-Engine:
·Wiseco 9.0:1 Forged Pistons
·Eagle "H-Beam" Rods
·ACL Coated Bearings
·05-06 TSX Camshafts
·Stainless Steel Valves
·Titanium Retainers
·Dual Stage Valve Springs
·NEW Precision 6262 Turbocharger (less than 500 Miles)
·Kiko Engineer Sequential Fire 1-4-3-2 Turbo Manifold
·HKS Super Sequential Blow-Off Valve with TIAL Wastegate (44mm) Silver
·AJP Front-Mounted bolt-on Aluminum Intercooler
·2.25″ and 2.5″ Aluminum Intercooler Piping
·3" Intake Pipe w/ K & N Air Filter
·3″ Downpipe w/ 3" Magnaflow Exhaust
·Stainless Steel Dumptube
·Stainless Steel-Braided Oil Feed/Return Lines
·2 Walbro Fuel Pump 255lph (2 pumps)
·FUEL INJECTOR CLINIC injectors Part #IS116-2150H (2150 cc) and Connectors.
·Golden Eagle High Flow Fuel Rail (Black)
·Aeromotive Fuel Pressure Regulator
·AJP Fuel Return Kit
·AJP Modified Oil Pan
·AJP Vacuum Block
·07-10 Civic Type-R Throttle Body
·05-06 RSX Type-S Oil Pump
·AJP Stainless Steel Catch Can w/ One-Way Check Valve
·ARP Head Studs
·Crankshaft & Pistons Balanced & Blueprinted
-Electronics:
·Hondata FlashPro
·Custom Tri Gauge Holder
·AEM Gauge-Type Wideband UEGO Controller
·Auto Meter Phantom II Oil Pressure & Boost Gauges
·Super White HID's
-Chassis & Suspension:
·17" Koing Kolors Wheels(Matte Black ) w/ Michelin (80% Tread Remaining)
·HFP Shocks w/ Eibach Sportline Springs
·Tanabe Under Chassis Brace
·Stoptech Drilled & Slotted Front Rotors(Cryo Hardened)
·HFP Rear Slotted Rotors
·Stainless Steel Braided Brake Lines w/ High Temp Brake Fluid
·McGuard Wheel Lock Set
-Transmission:
·Transmission Rebuilt at 102,000 miles (New Gears, All Bearings Replaced, Double Thrust Washers for reinforcement, TSX Final Drive, New Gear Housing)
·Synchromesh Transmission Fluid
·Omni Clutch Master Cylinder
·NEW Competition twin Disc clutch less than 500MILES!
·P2R Black Stainless Steel Braided Clutch Line w/ High Temp Brake Fluid
·TWM Short Shifter Kit w/ TWM Shifter Bushings
·Civic Type R Shift Boot
EVERYTHING ON ENGINE BUILT IS LESS THAN 3k MILES AGO!!!!!!!! EVERYTHING NEW NO SHORT CUTS TAKEN ON THIS BUILT!!!!
$12000FIRM!!!!!!!
954-400-867four Javier
-Engine:
·Titanium Retainers
·AJP Vacuum Block
·ARP Head Studs
-Electronics:
·Hondata FlashPro
·Super White HID's
-Transmission:
$12000FIRM!!!!!!!
dave1234
02-11-2008 07:43 PM
dave1234
Northeast (Sales)
02-08-2008 05:16 AM
