Where to source out new ecu pins.
#26
Re: Where to source out new ecu pins.
Well, some have been listed by myself and the post before yours B18c1turboedEK.
Everyone who doesn't share is stupid when it comes to these things.. If they found them.. you will.. it just takes time.. the fact that most places sell these pins for a silly amount of money is just asking for it, when no one buys stuff from them anymore.
If you click on some of the links that B18c1turboedEK provided they appear as if they are the female small and large pins along with the A/B/D OBD1 connector plugs for that half of your project.
As for the other pins I would look here
http://www.bmotorsports.com/shop/ind.../cPath/109_172 This tells you that the pins will be made by Amp/Tyco .. on a side note
DSM's use http://www.bmotorsports.com/shop/ind.../cPath/109_130 Delphi / Packard.
This is a link to Delphi's parts catalog
http://delphi.com/pdf/contact/brochu...balCatalog.pdf
This is a link to Tyco's part's listing.. It's not setup the same way and doesn't have the same easy single pdf listing, or none that I can find but here it is
http://www.tycoelectronics.com/compo...E_showAll=true
I don't know of anyone buying new pin's for things like EGR/Iat/Map those types of connectors.. and I think ChaseBays uses a donated engine harness for frakensteining one together for the end customer. I don't believe they use NEW physical connectors.
Although If you find something, feel free to post it here.
Generally what a lot of people do, and by a lot I mean not a lot.. is reuse the old sensor ends, snip about an inch off clean them really well and go to town.. this is helpful since the sensors still have old wire visible which help you diagnose connector problems using the real honda service manual..... that is if you keep the same sensor end with the same sensor your connecting it too!..
This way you can still use the honda service manual for wire issues should they come up.
Hope this helps! feedback appreciated.
---Aaron
*Edit
Actually I think B18c1turboedEK provided the Sumitomo parts listed here
http://www.bmotorsports.com/shop/adv...words=Sumitomo
and I just realized I typed a whole lot.
I think a company would benefit from selling a complete obd1 and 2 and whatever else wiring kit from scratch! not sure what a reasonable price would be... but wiring is expensive.
---Aaron
*Edit
yeah i know of those sites you listed theres just so many different pins they make its crazy hard to find the ones i need lol ..... and yeah chase uses all new wire and all new pins even for map/tps/iat etc. he uses the donor harnesses for the connectors them selves he depins all of them and then uses them on the new wire and new pins.
ps u can never type too much all help is appreciated !!!
thanks chris
#28
Personally it's not for the faint of heart.
If I were do do this again I would have the engine on an engine stand attach a plank of wood too it about 4 feet long screw the ecu to the other end of it and run each wire to the ecu, un broken.
Any wires that go from sensors to the car, and any wire that goes from ecu to the car would be on a custom connector.
Grounds/ECT/VSS/Power/Clutch/Oil Press/.... Probably a few more I fail to remember this early in the morning. Honestly the fire wall connector is cool looking, but In my mind completely un necessary.. I know I have made a comment to my friends about Honda's are like lego's but how often are you taking the engine out...
Basically the idea is to wire up the obd1 engine like obd2 one piece harnesses. And if your a creative person such as myself, i would probably try and use an existing left over connector for the wires that go to the dash from the engine, and from the car to the ecu.
Oh and save yourself some headache if any of you do this, make the ecu wires a foot longer then necessary and twist them up somewhere hidden under your dash.
#30
#32
The goal here isn't to sell stuff on this post, its to give people part numbers so they can find the parts themselves.
#34
any part # for the crimping tool Chris?
TIA
/Clyde
...these injector boots are nice addition to our harness i guess
http://www.classicricambi.com/index....&cPath=143_135
TIA
/Clyde
#36
Hello guys,... new member here, first post.
I am helping a friend with a 2j vvti swap into a mk3 supra and looking @ using the honda 1050 ems and was searching making my own harness when I came across this thread.
In searching for the pin numbers and such I came across this:
http://96-32-115-198.static.oxfr.ma....5698,5699,5700
Now I'm not sure how I got to these when I was searching the numbers..... But I'm going to order #3 On monday since it's only 2 bucks..... I will post back if by some stroke of luck I am correct.
#39
What about the new Sensors plugs & pins like Vtec,ect,iat,distur,inj,all Engine sensors plugs & pinout.
Love this thread thank you!
#40
Just throwing this out there again. Since it seemed like someone skipped over it.
These parts are from AEM Performance Electronics
35-2610 - Should be able to find it for around $60.54
35-2611 - Should be able to find it for around $60.54
#41
DUN DUN DUN... The thread thats back from the dead.
--Aaron
Rtype16 good find.. I might build another car at some point and I want all fresh new connectors.
--Aaron
#42
Thanks Guys
Keep It Up Useful Thread!
If Any one have links involved post it up..........
#43
This thread has been a big help so far, It would be even better if someone had some good heatshrink and sleeving sources as well as the pins for the honda engine connectors.
Thanks guys, lets make it happen!
#44
@ likwidchz thanks homie but im not talking about the actual sensors them selves ... i plan on reusing all of the sensors ... im reffering to pins that are in all the sensor plugs trynna make a harness from scratch new wire and pins etc.
many will say ask chase or rywire but the only thing they will do is sell you pins they wont tell you part numbers ...so i was wondering if any one else had this info. please help if any one does thanks !
Honda enigne plugs etc.
These are the plugs and the pins for obd2 civics and integras. i have found most of them but not all.
I am missing the plugs used for the IACV, ECT, etc, the Injector plugs, and the MAP, TPS plugs. If anyone knows which plugs they are please let us know. I do know the TPS/MAP plugs are made by the same company (Sumitomo). I am not sure who makes the others.
now that we have the part numbers, where can we buy these? i know Ballenger Motorsports sells some of these but not all. is there anther source out there?
HW Sealed Series Plugs
VTEC solenoid plug
Female - F(6189-0386)
male - M(6181-0227)
2pin plug (reverse lights & others)
Female - F(6189-0129)
male - M(6181-0070)
VSS plug
Female - F(6189-0130)
male - M(6181-0071)
O2 plug
Female - F(6189-0132)
male - M(6181-0073)
6pin plug (cruise control & others)
Female - F(6189-0133)
male - M(6181-0074)
8pin plug (OBD2B dizzy)
Female - F(6189-0134)
male - M(6181-0075)
10 pin (blue plug, pwr/grnd for engine harness)
Female - F(6189-0135)
male - M(6181-0076)
14 pin (pwr/grnd for engine harness)
Female - F(6189-0136)
male - M(6181-0077)
HW series pins
note: sold in reels of 5000
male - M(1500-0105)
Female - F(1500-0106) - brass
F(1500-0110) - heat resistant copper alloy
HW wire seals
note: sold in pack of 2000
gray - (7165-0385)
brown - (7165-0119)
blue - (7165-0118)
plug for empty ports - (7161-9787) note: sold in packs of 1000
HX Sealed series plugs
OBD2A dizzy
Female - F(6189-0555)
male - M(6181-0381)
HX sereis pins
small pins
male - M(8230-4472) cable diameter 1.4 - 2.4mm note: reels of 4000
M(8230-4562) cable diameter 1.8 - 2.6mm note: reels of 3500
M(8230-4552) cable diameter 2.1 - 2.9mm note: reels of 3500
female - F(8240-4862) cable diameter 1.4 - 2.4mm note: reels of 4000
F(8240-4992) cable diameter 1.8 - 2.6mm note: reels of 3500
F(8240-4952) cable diameter 2.1 - 2.9mm note: reels of 3500
large pins
male - M(8100-0463) cable diameter 1.4 - 2.4mm note: reels of 3000
M(8100-0464) cable diameter 1.6 - 2.9mm note: reels of 3000
M(8100-0465) cable diameter 2.6 - 4.1mm note: reels of 2500
female - F(8100-0661) cable diameter 1.4 - 2.4mm note: reels of 2500
F(8100-0660) cable diameter 1.6 - 2.6mm note: reels of 2500
F(8100-0468) cable diameter 2.6 - 4.1mm note: reels of 2500
HX sereis seals
small
gray - (7165-0385) note: silicone, cable diameter 1.2-1.7mm packs of 2000
blue - (7165-0118) note: rubber, cable diameter 1.7-2.4mm packs of 2000
brown - (7165-0119) "" cable diameter 2.1-2.9 ""
large
brown - (7165-0172) note: rubber, diameter 1.3-1.9 packs of 1000
gray - (7165-0130) note: rubber, diameter 1.8-2.9 ""
black - (7165-0131) note: rubber, diameter 3.0-4.1 ""
HX series plugs
small - (7161-9787) note: brown sold in packs of 1000
large - (7165-0145) note: gray ""
interior wiring
gauge cluster plugs - MN series connectors
if you need these you can find them on their site
dash and floor harness - HE series connectors
ditto
#45
Here is a good link but not shore if they do have the heat shrinks.
Wire ultrawrap Mill spec and more.
Example
http://www.keepitcleanwiring.com
likwidchz
Sorry for this is out off the subject....
#46
Here is a link for Insulation Supply Company in Torrance, CA. They have Raychem DR-25 usually in stock. This is where I pick it up if I need some in a crunch. Not sure if they sell to the general public though.
http://www.inscoinc.com/
#47
I found all of my spare pins and a few shells I needed to complete my harness here:
http://www.newunitedracetech.com/shop/
You can order whatever quantities, shipping is a little steep but prices aren't bad otherwise.
#48
#50
does any1 know the par# for the obd2b plugs?
You can find all sorts of plugs at; http://www.newunitedracetech.com/sho..._79_80_81.html
im not sure whats what... i wanna build a obd2b to obd1
chek out everything of the multilock section...
