Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Engine Management and Tuning (https://honda-tech.com/forums/engine-management-tuning-124/)
-   -   Spark Plug reading (https://honda-tech.com/forums/engine-management-tuning-124/spark-plug-reading-2994638/)
foodkeeper Nov 1, 2011 12:11 AM
Spark Plug reading
4 Attachment(s)
changed my plugs and put new ones, after 3 days i checked them. and i found this.
are they any good? any feedbacks would be appreciated! thanks.:thumbup:
Plug A
seems half of insulator tip is darker than the other side.
Attachment 450713
Plug B
dont know if its just dirt on the insulator tip.
Attachment 450714
EDIT:
after a couple of miles, maybe 150kms, heres what they look like.
Attachment 450715
Attachment 450716
why is it that a portion of it is black and the rest is tan/brown? could too much timing cause it to be black? i guess its not lean anymore, the earlier pics i posted were just driven for i guess 30 kms.
Dioxine Nov 1, 2011 12:49 AM
Re: Spark Plug reading
They look fine but i wouldn't have guessed they only had 3 days on them. B looks like it just has some carbon spots on it. The first one looks like its been burning up on the one side. Idk just my 2 cents, might want to get some advice from someone who has more experience with this kinda thing. What kind of motor are they in and is it modded at all.
mouab18c1 Nov 1, 2011 01:43 PM
http://www.theultralightplace.com/sparkplugs.htm
GhostAccord Nov 3, 2011 11:49 AM
Looking at where the color changes on the ground strap they look like they might be running a bit on the hot side.
What heat rating are these plugs? (Plug part number?)
nonvtecallmotor Nov 3, 2011 08:48 PM
Thats NOT fine. Too lean and too much timing.
foodkeeper Nov 5, 2011 12:22 AM
GhostAccord,
its a NGK bkr6e-11.
nonvtecallmotor,
after a couple of miles, the plugs seem to be brown colored on one side, and the other side, black, as shown on PLUG A. it should be brown all over the porcelain thing right?
i dont hear any pinging or detonation though.
ill try reducing the ignition timing.
siregcivic Nov 5, 2011 02:42 AM
looks to me like its too lean and too much timing...
what is your motor setup? and also usually black spots like that could possibly be carbon buildup but after 3 days i dont think so that usually is signs of detonation
my plugs after tuning a car are usually a light brownish color not white...
i would get a wideband check your fuel pull some timing or switch to a step colder plug but again depends on your setup
edit, also get a hacksaw and cut the very bottom of the plug, where the threads end closest to the base of the plug completely off but leave the insulator, also a good way to check how thick the fuel band is helps make sure its not running too lean
foodkeeper Nov 5, 2011 08:42 PM
2 Attachment(s)
after a couple of miles, here's what they look like.
Attachment 450615
Attachment 450616
siregcivic Nov 6, 2011 01:45 AM
what is your setup? what is your compression?
my friend has an ls all motor with ctr pistons and i told him to get ngk bkr7 and his plugs look nothing like yours they look normal but i also made a 5 layer headgasket for him because his compression was going to be in the high 12's lol but my guess is around 12.3 now but there is no black spots on his plugs or anything...
who tuned your car? could be too lean too much timing running too hot cylinder temps like i said you might need to get a colder plug but i would need to know your setup before telling you to do that
foodkeeper Nov 6, 2011 01:54 AM
its a stock sohc D16ZC vtec. stock compression.
siregcivic Nov 6, 2011 12:54 PM
what ecu are you running? and where is your distributor set at?
MrDomino Nov 6, 2011 04:24 PM
How do you know if the engine is rich/lean and that the timing is off? I know it has something to do with the location of that "band" on the ground strap but nothing more than that.
akenwph Jul 8, 2017 03:16 PM
Plug A
https://i1205.photobucket.com/albums...odkeeper/3.jpg
Plug B
https://i1205.photobucket.com/albums...odkeeper/1.jpg
EDIT:
https://i1130.photobucket.com/albums...Picture022.jpg
https://i1130.photobucket.com/albums...cture020-1.jpg
Hey I dont want to make a new thread but I am having simlar reading from my spark plugs half of the insulator tip seems burnt like the pic shown above does anyone know why it may be like that?
