Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Engine Management and Tuning (https://honda-tech.com/forums/engine-management-tuning-124/)
-   -   s300 datalogging (https://honda-tech.com/forums/engine-management-tuning-124/s300-datalogging-2569003/)
jdm inc May 14, 2009 09:45 AM
s300 datalogging
I was needing some info on how to hook a switch up for the datalog on the hondata s300 any help is appreciated. Thank you.
93turbo16 May 14, 2009 11:18 AM
Re: s300 datalogging
Do you need help with a switch for the on-board logging feature?
If so it is very simple.
jdm inc May 14, 2009 11:22 AM
yes if you could give me some insight i would highly appreciated, thanks
93turbo16 May 14, 2009 11:28 AM
If you want to run a switch for the on-board logging all you have to do is choose an input in the program that you want to run the switch to.
I would suggest using the A/C input. It is a grounded input. So run one side of the switch to chassis ground and the other side of the switch to pin B5 on the OBD1 ECU.
When you flick the switch and it grounds the pin at the ecu it will enable on-board logging.
jdm inc May 14, 2009 11:33 AM
awesome!!! Thanks bro!
I just didnt know where the other side of the wire on the switch went.
Thanks a alot bro...
