Please advise on my AFR.
Got my car on a rolling road last weekend. Made reasonable power- 169.5bhp on a dyno dynamic roller (which i gather read a touch low)
Was hoping for a touch more. Got a print out of the AFR and it looks a little, er, lumpy to me! Spec is 120,000 mile b16a2 block Fujitsubo B18 manifold (4-2-1) Sports cat Tanabe 60mm Hyper Medallion exhaust Mugen airbox Ignition timing at 18 deg BTDC Cam timing advanced 2 deg at inlet and retarded 2 deg on exhaust using skunk2 cam gears (might be other way around-!?) Stock 99 si ecu Can anyone advise on whether this would benefit from some mapping? Can anyone talk me through what the graph is telling me? AFR http://i24.photobucket.com/albums/c4...s/P1020306.jpg HP and Torque http://i24.photobucket.com/albums/c4...s/P1020307.jpg |
Re: Please advise on my AFR.
nice. looks like the range is 12.4-12.8. which isnt that bad. pretty conservative. you could lean it out quite a bit more to make up for lost power. shit my b16 on 12 lbs im seeing close to 12.4 afr's on a cold night. ive even seen 12.6-12.7.
The plugs are all fine but the afr varies across the load/rev range. Surely its about making the AFR right at as many load sites as possible..? No?
mapping will def show improvments. u can lean the a/f a bit and it will gain u some HP
