OBD1 ECU COIL ON PLUG MODULE - TROJANTUNING
#27
Re: OBD1 ECU COIL ON PLUG MODULE - TROJANTUNING
You need the variable reluctance sensors in the distributor working for this hack to work. So if you need a distributor, unless its just the rotor or cap, youre still going to need to replace it in order to run coil-on-plug.
#28
#29
Good job!
In later engines (such as F23's as I know), the sensors are located at the crank pully side of the engine. I think in those engine the dizzy is just working as a distributor and coil, not like the older ones which contain sensors too. If I'm correct, you could completely remove the dizzy in those engines; Which makes the bay more shaved and clear. What you think?
#30
what do yo mean ? the only thing that is need it is the arduino connected , and original coil to be disconnected . (replaced with a 320ohm resistor for rpm to work) but thats it .
#31
I love the idea , thats why my test car was a d17a2 civic 2002 , because I wanted to use the sensors that are already there , but I wasn't able to accomplish that , but still at work with that .
#32
The coil switching with any high speed transistor? or mosfet? Or direct arduino wiring to the coil?
#34
I'm sorry but we haven't given any unit to test to anybody , I belive Manolito from Puerto Rico requested one to us for testing when he came to Costa Rica, but we haven't talked about this clearly
#35
#36
What you using to connect INJECTOR and ICM (12v singal) to 5v arduino input? a zener diode ? I see on the picture something in black cover on the wire but have no idea what it is.
#37
from ICM to the INPUT pin on the arduino Im using a 1k resistor 1/8w , also for the sync (INJ) , for each coil Im using a diode.
#39
Curious which signal you are using for sync? Is it the CYP, TDC, or CKP output from the distributor? I'm building this up and will start playing with your code asap. Any interest in emulating the tach output? I think it would be worthwhile to simply do away with the entire distributor and have a 24-1 (or 36-1) optical wheel and use the arduino to emulate all the stock distributor outputs to the ECU. If done right we could do up a board to stuff it all inside a distributor-like device.
#40
#43
I did some serious thinking about this over the weekend...If I'm not mistaken this can also be done with some CMOS logic. A CD4017 decade counter chip seems like a suitable solution. Anyone have thoughts on this? You'd use the tdc signal from the distributor to reset/sync the count. A circuit like this could be hidden inside a gutted distributor and the coilpacks wired directly to it.
This is this signal diagram for the counter:
I think this could also handle the tach output as well?
#44
Hi guys, Adeel here hope you are fine. I have a honda City (SX-8 or Type Z ) swapped with a D17A engine and a manual ECU. I researched on ho to convert it into OBD 1 but having no background in coding or programming i am not able to break the barriers. However, here i can say that using a simple Logic IC cannot be a solution as Dwell Time is very difficult to set in this situation or fine tune. On the other hand we will be needing a simple code to tell the arduino that what a short pulse means but it is not that easy. Well the code that is posted over here is now working for my D15 test engine maybe it has some code missing.
we can use 4 VR sensors to trigger 4 coils instead of 4 wires but the circuitry will be complex. While looking around for answers i found speeduino.com where a member is using arduino as an ECU to run a D15 Vtec.
@amadeuscr can you please comment on the usability of the posted code or can you upload a complete version of it. or shed some light on it.
#45
This is the new revision of the code , which includes min and max for dwell to be mapped into rpm , and it has OFFRET , which is to offset the timing for retard . and will do it in mapped microseconds level, right now its commented cause I have no need for it anymore , it looks like the timing its working properly.
#46
#47
and I just posted the new revision of the code .
#48
I'm going to build this up and I need some help in installing the arduino and wiring. Do you have any images or diagrams or etc. to help us with it?
#49
http://speeduino.com/forum/viewtopic.php?f=19&t=206
Here it is .....
Hi, thank for your prompt response @amadeuscr ...... having some issues controlling dwell time ...... can you post a base map that ran D17. I have another project going. Converting a D17 into OBD-1 and my car too ..... any sugeestion which basemap/rom to use. If you could post it will really pace up my work, if you dont mind. i will also be trying the VR sensors hooked up to trigger coils no dwell issues .......
Here it is .....
