LS/VTEC basemap
Hi
I have a b18a1 + b18c1 fitted with 9:1 pistons, with obd1 distributor and Neptune RTP. Is the standard P72 basemap good for the car for the break-in period ? Should I check some stuff ? Thanks. |
Re: LS/VTEC basemap
If you are using a stock set of injectors & you have a wideband oxygen sensor to monitor everything, you should be good to go.
| All times are GMT -8. The time now is 03:00 PM. |
