Misfire at idle need another brain
Old 06-20-2011, 07:20 PM
tobster's Avatar
Default Misfire at idle need another brain
D16 vitara build with zex cam 1000cc precision injectors vehicle ran and idled perfect obd2 stock injectors and stock computer. installed 1000cc and chipped p28 added my tune and it idles at 14.7 a/f but has a misfire my plugs were gapped at .025 because thats what everyone is saying they should be. i tried .o30 and seem maybe a little better the whole ignition system is brand new and worked before injector install. making me think bad injector but they all ohm out and can hear them all click its not a dead miss. and also clears up higher in rpm and goes down the road nice its just idle is there something im missing
Old 06-20-2011, 09:02 PM
d112crzy's Avatar
Default Re: Misfire at idle need another brain
What brand injectors? Try making it a bit richer.
Old 06-21-2011, 05:10 AM
tobster's Avatar
Precision 1000cc are u thinking its a lean misfire just to much fuel not beaing able to burn at idle
Old 06-21-2011, 03:42 PM
tobster's Avatar
its my tune thanks
Old 06-22-2011, 06:12 AM
tobster's Avatar
learned alot last night started off making my own base map and everything is now working wonders learn somthing new everyday car is almost done now woooo hoooo
civickiller
05-12-2010 02:10 PM
cbustuner
03-24-2008 10:38 PM
boostedh22a
05-06-2006 05:58 PM
KooK
02-16-2006 07:14 AM
Quick Reply: Misfire at idle need another brain
