Hondata S300 OBD1 P28 B18A1
Old 07-20-2017, 01:07 PM
lolv8s's Avatar
Default Hondata S300 OBD1 P28 B18A1
I'm running an OBD1 P28 in my 1996 Integra with a B18A1 swap I built. 9.6.1 compression. Stock cams and cam gears. Brian Crower valves and valve springs. I disabled VTEC because I don't have a VTEC head. What else should I change? I'm new to Hondata and I'm just getting ready for my engines first start all stock. What else should I change?
Old 07-20-2017, 01:12 PM
lolv8s's Avatar
Default Re: Hondata S300 OBD1 P28 B18A1
I'm also new to Hondata so please be understanding lol. Today was the first day I've used it. So please understand when I say I'm new to this.
Old 07-20-2017, 04:35 PM
2x0
2x0's Avatar
Just load the stock basemap for your engine (or the closest one to it) that is built in to Smanager and the car should start and run fine until you go get it tuned.
The only thing you should have to change is the injector sizing and dead time if you are not using oem injectors.
Old 07-21-2017, 06:28 AM
lolv8s's Avatar
ok cool. So a few minor changes. Im running oem injectors before I mod and turbocharge it. Thanks for the help. Is there a way I can change the compression or is that not required?
Old 07-21-2017, 08:13 AM
lolv8s's Avatar
how would I pick the basemap? what would they be labeled as?
Old 07-21-2017, 08:45 AM
2x0
2x0's Avatar
The compression will affect the timing and fuel your engine needs, which comes into play when you get it tuned, but there are no parameters you can adjust for that.
In SManager, go to File > New. The base calibrations are labelled by ECU code and it give a description of the cars they came from.
Old 07-21-2017, 10:05 AM
m4xwellmurd3r's Avatar
Smanager has a b18 non-vtec map. Do you have a wideband installed? I don't know if it's because of my increased compression and displacement (81mm to 81.5mm and stock compression to 10.8:1) but the LS map they had ran pretty lean on my car. I know it was the map because when I ran my OBD0 LS ecu the engine's AFR's were dead on how they should be. The LS map smanager had, had my car WOT at 17:1 AFR's
Old 07-21-2017, 12:48 PM
2x0
2x0's Avatar
This is why you should never run WOT on a basemap after making changes to the engine. It is only meant to get the car running so you can take it to a tuner.
Old 07-22-2017, 09:54 AM
lolv8s's Avatar
ok thank you for the information. Will it be ok to run the engine before I get it tuned? I wanted to run the break in procedure. But I don't want to mess things up either.
Old 07-22-2017, 09:56 AM
lolv8s's Avatar
I turned the VTEC off. and no wideband, yet. I'm getting things ready to just run stock.
Old 07-23-2017, 08:32 AM
lolv8s's Avatar
would I change it to a car my B18A1 came from? (DA Integra 90-93) So a PR4? And I'm not seeing a PR4 available so would I just change to P74?
Old 07-23-2017, 03:26 PM
2x0
2x0's Avatar
Theres a Hondata help forum on their site with experts that will better assist you.
Old 07-23-2017, 05:40 PM
lolv8s's Avatar
ok appreciate that. I'm just seeing all files and I've been searching. Could anyone maybe give me a quick answer?
Old 07-26-2017, 11:13 AM
lolv8s's Avatar
bump
NHswaps13203
Northeast (Sales)
07-14-2006 05:48 AM
93h22a1vtec
03-17-2006 02:58 PM
NirVTEC
02-17-2006 10:21 AM
91civic4drboy
12-03-2005 10:55 AM
Quick Reply: Hondata S300 OBD1 P28 B18A1
