Help with Kpro and other issues , K20/EM2 datalogs inside
Ok, so first off ill say that I am new to K series and have never tuned a car. I just picked up an 01 EX with a K20a2 swap. The trans was locked up when I bought the car, so I never test drove it. I put a used RSXS trans in it and when I finally drove it, I noticed a few problems.
1.) Primary O2 wasnt responding, so I bought a new OEM RSXS sensor (wideband). That issue is fixed. 2.) There is a horrible vibration (feels like a wheel is about to fall off) in the pass front when turning the wheel to the left. Its more noticeable at higher speeds and seems like it is more noticeable after a hard acceleration. I thought it was an axle, so I sent the axles back to Gator Racing to have them rebult. That did not fix the problem. 3.) The headlights and dash lights dim randomly when theres a load on the engine. Im not sure if this has something to do with the ELD. I tried turning it off in Kpro and it didnt make a difference. 4.) A short time after a full throttle pull, the car will start breaking up real bad. It does this at any TPS%. ie, theres no change if im light throttle or hard on the throttle. I also noticed that the speedo drops or bounces around when this is happening. I swapped the VSS out and no change. 5.) I took a few datalogs and my AFs are def too lean in the 14s at WOT!! 6.) at one point I got a error code for a "multiplexor communication error" I dont even know what the eff a multifluxcapacitor is! The first datalog is with the tune stored in the Kpro files for 310cc, BC2's, Toda Header... etc. The car freakin rips with this tune! But still has all the above issues. The Second datalog is with the tune that was in the ECU when I got the car. The kid I bought it from swears up and down that it ran great with this tune.... I surely doesnt now! The 3rd tune is the BC tune again from the first log. The car did the breaking up / studdering in all of the logs. The mods on my car are: 01 Civic EX K20a2 -PRB w/Kpro -BC stg 2 cams, springs and retainers, RBC cam gears -RBC intake -Comptech header -3" Buddy Club exhaust -Short ram intake w/ blox v stack and K&N -I was told that this engine was rebuilt and has higher comp pistons, but I have no way to verify that. -Stock 310cc injectors (I believe). They say RA17 BAH on them. |
Re: Help with Kpro and other issues , K20/EM2 datalogs inside
hmm ok apparently I cant upload the logs... it sas invalid file when I try.
Can I post Kpro logs in this site? Anyone know how to convert them so I can upload if possible? |
ok, so nobody on honda-tech has ever attempted to post a datalog up then... cool
Cool, thanks for all the help guys!
| All times are GMT -8. The time now is 06:02 PM. |
