Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Engine Management and Tuning (https://honda-tech.com/forums/engine-management-tuning-124/)
-   -   Distributor mess (https://honda-tech.com/forums/engine-management-tuning-124/distributor-mess-3043785/)
Joacnel Apr 4, 2012 10:27 AM
Distributor mess
I have an OBD1 LS head but OBD2 bottom end from a 98. I'm using my hatchbacks D16Y7 engine harness since I was told it should work just fine. Can I use an OBD2 distributor on this LS?? I tried using my D series but I figure the bolts don't match up due to it being a single and now this being a dual it's a different pattern.
mtber Apr 4, 2012 07:02 PM
Re: Distributor mess
You can use an obd2 ls or b20 distributor...
You can also use an obd1 ls distributor & simply purchase an obd2 engine harness to obd1 distributor jumper: http://www.phearable.net/shoppingcar...per-p-101.html
