Crower 404 Cams Idle Issue
Okay i just swapped my ls head to a built ls head. I have it idling pretty good, but seems to have less vacuum. Is this normal? Sitting at 500ish mbar and at 800-900rpm.
Cam gears 0,0 Cant get igntion timing to advance to 16* with distributor fully advanced. It's more retarded atm. http://i937.photobucket.com/albums/a...c-87/crx_2.jpg |
Re: Crower 404 Cams Idle Issue
Ls block have b16 pistons 10.8-11.0 compression
Do those cams have a lot more duration than stock cams?
Yes, they do have a lot of duration. Low idle vacuum is what happens on big cams
It also sounds like your mechanical timing might actually be off if you cant get it set to 16 degrees after engaging the timing lock in your tuning software (if it can do that) |
Originally Posted by v4lu3s
(Post 50575027)
Stock Specs B18B IN / EX Advertised Duration 234 / 236 Duration @ .050" 194 / 196 Gross Lift w/1.75 395 / 380 Crower Honda / Acura - B18A/B & 1st Gen B20A Performance level 4 - Stage 3 - 3⁄4 Race - Recommended for mostly strip use in N/A applications. Rough idle. INT/EXH - Dur @ .050” Lift: 216°/214° RR: 1.75/1.75 Gross Lift: .445”/.434” LSA: 109° RPM: 1100 to 8200 Redline: 8700 |
Originally Posted by m4xwellmurd3r
(Post 50575052)
If you don't know how to lock it then how are you synchronizing ignition? Is the ignition output of the Ecu even 16*BTDC when you are lighting the mechanical timing? My guess is your big cams are pulling a low vacuum which is putting your idle region in an area with lower ignition advance and you are trying to sync your ignition at less than 16*. Whats your table ignition value at that cell in your screenshot? I bet its around 14*.
Originally Posted by Muckman
(Post 50575470)
If it's idling about 12.87" of vacuum @ 800-900rpm. Would syncing it to 16* be correct? I was told i need to advanced the camgears to be able to sync it in at 16* |
Did you degree them to the specs on the cam card? You need to start there if you haven't, and you need to measure and map your P2V clearances before you start moving things around.
Solved the problem. The cams are supposed to idle around that vacuum/area because of aggressive cam lobe.
Muckman was correct. I was trying to adjust ignition timing at distributor first then set it in the program after. Wrong lol.....So i synch program to 16.5* then adjust at distributor and got it synch correctly, but distributor was advanced all the way. Either way it idle smoother....Thanks everyone. |
| All times are GMT -8. The time now is 10:37 AM. |
