B20 VTEC Fresh Build on base map (Incredibly Rich)
I have a B20 VTEC in my EG Hatch that has roughly 20 miles on it. I am on a Chrome base map and the car runs an idles good, except until it warms up the excess amount of fuel fouls out the plugs and causes a miss until its warm. I didnt notice it doing this until yesterday when i saw black specs coming out of my exhaust when it was cold. I then took it around the block and it started missing until it warmed up. I know i need to get a final tune, but i am on the basemap because I needed something for the first start.
My setup is: chipped p28 on chrome Jdm B20b block .20 over Ross Racing 84.5mm 9:1 compression pistons eagle rods thick cometic HG b16a SiR II head ported 01 ITR cams ITR intake manifold and 68mm tb supertech valves with 3 angle viton valve seals stock header with a test pipe and ws2 catback I am not sure what my tuner went off of to create my base map but it runs pig rich and I want to break it in NA before it sees boost. I asked him why he thought it was running so rich and he told me the low compression (9:1) is the reason why its running so rich. Does anyone think my issue will clear up with a tune? |
Re: B20 VTEC Fresh Build on base map (Incredibly Rich)
Your issue must be diagnosed in person by an experienced tuner.
Your issue maybe the basemap, an electrical issue or mechanical issue etc. Just because your c/r is 9:1 and he provided a basemap for something with more compression, the car shouldn't run off the charts rich. |
well i do not have a wideband so I can not tell where the a/f ratio is
i am assuming that it is running rich though because I can see what looks to be unburnt fuel coming out of my exhaust on cold starts and under WOT it smells very rich
Anymore input?
Here is a quick list of things I would point to:
1. Intake air temp sensor is faulty/plugged into the wrong 2 wire plug causing it to have melted etc. 2. Your timing belt is not setup at tdc 3. Your basemap is not right for your setup Good luck! |
my intake air temp sensor is brand new and plugged in correct, my timing is DEAD on, and my basemap is most likely crap
1 Attachment(s)
just a tad rich you think?
i bead blasted my plugs and i am going to try them today. ill keep the thread updated
solved til I get a tune
just wondering what injectors r u running in it
stock
i believe they are 240cc? correct me if im wrong
Hey what was the problem? I just finished my swap and it's having the same problem
tuned the car and it runs awesome
what was the problem? What spark plugs are you using and what gap they are set at and what gas did you tune it on?
i went from brk7e's to brk6e's and tuned it. its tuned on Crome using 93 oct.
