Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Engine Management and Tuning (https://honda-tech.com/forums/engine-management-tuning-124/)
-   -   8 injectors on hondata???? (https://honda-tech.com/forums/engine-management-tuning-124/8-injectors-hondata-2462199/)
sgnlab Dec 30, 2008 09:43 AM
http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
seen this today on ebay is it even possible?
mtber Dec 30, 2008 09:50 AM
Re: 8 injectors on hondata????
"The second set of injectors will engage when you hit Vtec thru the injector harness coming directly from this ECU"
Made me laugh a little.
My bet would be that they simply piggybacked the power/signal from the original injector outputs to try and sell the ecu as something special.
sgnlab Dec 30, 2008 09:58 AM
I figured that! But Hondata has to do something we need some 8 injector action out of the s300!
sander Dec 30, 2008 03:51 PM
Id be careful with that, the drivers may not be able to handle two sets. That is asking alot of the computer.
quicksilver1689 Jan 1, 2009 03:10 PM
yeah injector drivers might take a poop
boosted hybrid Jan 1, 2009 04:33 PM
That is actually my old 8 injector ecu that was done through Raver motorsports. It uses another set of factory injector drivers that are powered via vtec solenoid on the board. When vtec is turned on, the secondary set of injectors turns on as well. It works really well actually. You just have to scale the secondary vtec fuel map to compensate for increase fuel flow from both sets. Raver motorsports did a bunch of those ecus for the edelbrock 8 injector turbo kits they were selling. Its actually really reliable since the injector drivers are OEM honda, but both sets of drivers are saturated.
SovXietday Jan 1, 2009 04:40 PM
^Neat, how is tuning the crossover with that though?
boosted hybrid Jan 1, 2009 04:49 PM
Pretty decent if you have the secondary vtec fuel map scaled properly for the combined flow of the injectors. There is still a quick "rich" blip on the crossover but you cannot feel it. I would just as soon switch over to aem ems and run 8 injectors in staged control. Much more control over secondary injectors, and pretty simple to set-up. You can phase the secondary set in via load/rpm just like the main VE map.
sander Jan 1, 2009 09:06 PM
Oh ok, thats a pretty cool idea!
quicksilver1689 Jan 6, 2009 08:01 PM
stupid 08
