problem with " moving idle speed "
Old 12-16-2011, 09:00 PM
99black_em1's Avatar
Default problem with " moving idle speed "
hi , i have an all motor B tuned with a s300. The cams have big primarys so getting them to idle was tricky. After playing with the timing , AFR, and the idle screw on the TB , it is now idling steadily at 900 rpm. Ive also adjusted the IAC duty to steady instead of dropping too low after revving. When the car is moving , and im coming to a stop , i notice that if the rpm is above 3k , and i put it to neutral , its fine. But if i let it decel in gear , and put it to neutral at around 1.5-2k , it drops low to like 500rpm , before bouncing back up ( sometimes drop too low and it just dies )
any idea on how to fix this ?
Old 12-17-2011, 09:43 AM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Default Re: problem with " moving idle speed "
What is your fuel cut resume set at?
Old 12-17-2011, 09:31 PM
"fuel cut resume" ? .. where can i find this setting in the smanager ? .. ill take a look.
Old 12-18-2011, 08:16 AM
v.i.gsr's Avatar
Try playing with the fuel overrun settings in the tps paramater..
Old 12-21-2011, 02:33 PM
thanks for the suggestion. I changed the percent in the fuel overrun from 0.6 to 1.3% and then to 2% without any changes ( ignition off ) . any other suggestions ?
92vtechhatch
09-13-2010 08:15 PM
DeucEG
05-02-2010 11:41 AM
ge_itr
10-16-2007 05:12 PM
pvp329
11-14-2005 11:04 PM
BoostedD15B7
11-12-2003 05:53 PM
Quick Reply: problem with " moving idle speed "
