Hondata S300 - P28 - Baro sensor error (code 13)
Hi, i installed an hondata s300 into a stock p28 ecu in a Civic with a D16Z6 Engine.
The problem is that when i turn ignition on, error 13 is displayed in smanager.... and fail light is on... if i turn on the engine code 16 (Fuel injectors) is displayed too...
If i plug a stock P28 into harness and turn on ingnition, no errors are shown in the engine light... and car works well.
What could be the problem?
Where is located the Baro Sensor? (i was reading that is into de Ecu... but where?)
Does anybody could help me with this?, the car is of a friend of mine...
Thank you!
Thank you!
Re: Hondata S300 - P28 - Baro sensor error (mtber)
Hey, thank you... i was looking for this options.. but i could find it... jeje, misc options i was looking in Map and (Options -> Settings).
I saw in some forums that some jdm ecus dont use this baro sensor... could i be on the right? and... if i disable this option.. what happened? less precision in data?¿?¿..
Thank you for your help!
Tomorrow i will test disabling this options, i will post the result.
Do you know or have a picture to show where is located this sensor in the ecu motherboard?...
Modified by sIrKicK at 1:12 PM 10/21/2008
Hi again, today i was configuring the ecu and the problem is solved with the two options disabled
Barometric Pressure Sensor Disabled
Injector Error Disabled
The car runs perfectly and all sensors works fine.
Thank you for your help.
Yesterday i only had 20minutes to check the ecu and go home...
Regards, ****.
Regards, ****.
Re: (sIrKicK)
One question...
i have another P28-G00, if i prepare it to hondata with resistors, chip, etc... and dont plug-in the HONDATA s300 into de Ecu.. the Ecu works fine like stock?¿
Because i want to prepare it to in the future buy another S300 for install into my other Civic.
snowseeker
08-29-2008 07:49 AM
